07-10-2011, 05:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | Iphone I5 china after format can't enter menu my phone is I5 China have phone code but can not read code so i format in safe mode now phone only show dial key can't enter menu of phone. I have backup full flash before format but write it can't help me get menu back. How to fix it? pls. Phone photo Full flash backup F10 PCB01 GPRS MT6253 S00.F10B V2 2 F5.BIN FLNS71VS128RB0AHK0L0 firmware 20110709 105905.B0M.bin http://www.mediafire.com/?n48c0em451vig6m -------------------------------- Last edited by vanhh; 07-10-2011 at 06:00. |
07-15-2011, 10:17 | #4 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | FFS Complete log: Code: COM3 [VCP0] selected module v3.30 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00BB]: 0001:007E00630001 [SPANSION] S29VS128R_T chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: F10B_V2.2_F5 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0 project-id: F10B_V2.2_F5, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/001E0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.30, database date: 17.04.2011): F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\ChineseMiracle\F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0__fullflash_20110709-182917.B0M.bin Format... Disconnect... done Finished, time used: 9 min 48 sec Remove/Install battery now ! Code: COM3 [VCP0] selected module v3.96 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0__firmware_20110709-105905.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00BB]: 0001:007E00630001 [SPANSION] S29VS128R_T chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: F10B_V2.2_F5 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0 project-id: F10B_V2.2_F5, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/001E0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.96, database date: 21.06.2011): F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\MModule\F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71VS128RB0AHK0L0__fullflash_20110710-102214.B0M.bin startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Format... autodetection mode... Format done Disconnect... done Finished, time used: 17 min 24 sec Remove/Install battery now ! |
07-18-2011, 19:46 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there was a similar problems on certain phones. they was solved by typing special code, different for each model. http://forum.gsmhosting.com/vbb/f425...0/#post5152706 To solve the menu problem on Star phones or BLU phones just type *#15987*# and voila menu unlocked. you can extract all service codes from you flash backup using program "informer". try each code and see result. i hope you will solve your problem this way |
07-19-2011, 05:18 | #7 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | Tried all codes i found but no have code solve my problem, in first post have flash backup F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71V S128RB0AHK0L0__firmware_20110709-105905.B0M.bin can U extract service codes for me? Thankx for support! |
07-19-2011, 23:09 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Loading file v.02... F10_PCB01_GPRS_MT6253_S00.F10B_V2_2_F5.BIN_FLNS71V S128RB0AHK0L0__firmware_20110709-105905.B0M.bin loaded Detecting codes... *#0966# *#0098# *#0092# *#0972# *#0886# *#0066# *#0084# *#0062# *#0060# *#0044# *#0086# *#33# *#331# *#332# *#35# *#351# *#62# *#61# *#67# *#21* *#43# *#0000# *#0066*# *#0049# *#0039# *#369# *#123456# *#654321# *#3871# *#00220807# *#00777755999# *#06# *#008375# *#003646633# *#00788# *#00123# *#0078# *#00789# *#0033778# *#00523# *#00678# *#00876# *#006810# *#001234# *#00900# *#00901# *#00931# *#00932# *#00933# *#00902# *#00903# *#0063342835# *#9835# *#62442243# *#7525# *#035670766*001# *#035670766*002# **5555555* **11# **89# **20# **61* **004* **62* **67* **21* **04* **042* **05* **052* ##62# ##61# ##67# ##004# ##21* ##002# ##765*05# ##765*08# ##765*02# ##765*07# ##765*78# #*0123456789#*0 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Hidden menu options | morianis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-10-2000 12:01 |
what's menu #11 and #12 of nokia 6150? | eiffy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-02-2000 22:09 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
