04-08-2011, 16:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Argentina
Member: 322470 Status: Offline Sonork: 1596253 Thanks Meter: 25 | iphone model 188 falil imei repair module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 354904041581682 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6E03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: TELSDA25_GEMINI_PCB01_GPRS_MT6225_S00.M188_OV_ALL_ V07.BIN project-id: M188_OV_ALL_V07, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 208818FFFFFFFF:20881800000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ....................... ffs/eeprom: detect std location pass #1... .................................................. .......... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 2 min 1 sec Remove/Install battery now ! |
04-08-2011, 19:25 | #5 (permalink) |
Member: 322470 Status: Offline Sonork: 1596253 Thanks Meter: 25 | same problem COM7 [VCP0] selected module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 355764004801207 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6E03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: TELSDA25_GEMINI_PCB01_GPRS_MT6225_S00.M188_OV_ALL_ V07.BIN project-id: M188_OV_ALL_V07, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 208818FFFFFFFF:20881800000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ....................... ffs/eeprom: detect std location pass #1... .................................................. .......... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 2 min 1 sec Remove/Install battery now ! |
04-09-2011, 16:39 | #7 (permalink) |
Member: 322470 Status: Offline Sonork: 1596253 Thanks Meter: 25 | problem solved in mode 2 thanks COM7 [VCP0] selected module v3.29 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 355764004801207 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6E03:0000 status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6225,E03 Date: 2006.06.14€ Version: 1.0€ Version: M188_OV_ALL_V07€€€€€€ Version: GWM18¼…w@@@€€ ==================== New firmware found (v.3.29, database date: 13.01.2011): M188_OV_ALL_V07€€€€€€ This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 0warning: wrong packet cs warning: wrong packet cs 1 2 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 5 11 done 67 byte(s) read verification... verification done: 35576400480120 Finished, time used: 51 sec Remove/Install battery now ! |
10-25-2011, 08:01 | #8 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1648429 Status: Offline Thanks Meter: 0 | i wonder how can i learn what u r guys doing i wonder how can i learn what u r guys doing, i wanna be able to read chip data. can i please ask what tool are u using guys ? and sorry for being such a nerd |
10-25-2011, 09:01 | #9 (permalink) |
No Life Poster Join Date: Mar 2005 Location: UGANDA Age: 50
Member: 126167 Status: Offline Sonork: 100.1591387 Thanks Meter: 5,128 | @unovip Hi , Your In Infinity section , That means u have to use Infinity-Box are u a programmer? , or just wannna try programming ? Br Last edited by hassanjinja; 10-25-2011 at 09:04. Reason: NOt original Iphone , Its chinese cloned. |
10-26-2011, 06:35 | #10 (permalink) |
Member: 1648429 Status: Offline Thanks Meter: 0 | Something else I see what u guys are posting, it is ok, but i checked the website of infinity box and it doesnt support reading the Iphone chips ! how did u guys got to read the iphone chip using it ??? i wanna read the iphone chip ! thanks in advance |
10-26-2011, 18:23 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
here, when we talk about Iphone we only mean cloned chinese copy. It is made on another CPU, so nothing interesting for original iphone owner | |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
