05-12-2020, 14:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | Itel A15 not accept flash Q1: Is it possible that one partition could be readonly Q2: Is wiping a partition same as resetting/factory reset Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : All_Itel_DA_by_MiraculousGsm.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017044453848870C0134E384290D DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100454838454434010C87D2984E3 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8ED4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D39A86D66BC5BCF9D237F9B1243D26E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-04-05 Build Time : 1525270947 Product Model : itel A15 Product Brand : Itel Product Name : VP510 Product Device : itel-A15 Product Manfct : ITEL MOBILE LIMITED Product Info : k80hd_bsp_fwv_512m Product Board : k80hd_bsp_fwv_512m Board Platform : mt6580 USERDATA : ENCRYPTED Done! Elapsed: 00:00:51 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_k80hd_bsp_fwv_512m.bin EMI : CNT : 0002 EMI : [00] : eMMC : DDR3 : ID : 700100454838434434 : VEN : KINGSTON | DEV : EH8CD4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : 700100454838454434 : VEN : KINGSTON | DEV : EH8ED4 : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :13 [FL] : Set : lk-sign.img [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : secro-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x45916148 [ 1.09 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :13 [FL] : Set : lk-sign.img [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : secro-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x45916148 [ 1.09 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :13 [FL] : Set : lk-sign.img [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : secro-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x45916148 [ 1.09 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : All_Itel_DA_by_MiraculousGsm.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017044453848870C0134E384290D DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100454838454434010C87D2984E3 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8ED4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D39A86D66BC5BCF9D237F9B1243D26E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 ERR : 0xC0010002 ERR : ABORT ERR : 0x00000000|0x00000000 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! I |
