05-23-2018, 23:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Itel it5330 restart problem ITELL IT5330 main problem is restart when press call so i have a new phone want to backup flash file and flash it to faulty phone i think it is sc6531 when i try to boot it give me :> 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! i try with all cpu what can id and how can i know which procesor inside it is spd but what ??? |
06-20-2018, 08:54 | #5 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Itel it5330 restart problem Hello. Is there way. To boot this phone. And. I work. With version 1.02 for last. Version i need renew support Last edited by helpo; 06-21-2018 at 06:49. |
06-21-2018, 23:46 | #6 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Itel it5330 restart problem Problem was from boot key Now it is boot and formated done. Phone found! [ 249 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Last edited by helpo; 06-22-2018 at 11:53. |
