11-17-2018, 14:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Somewhere In Africa
Member: 1503666 Status: Offline Thanks Meter: 30 | itel1408 stuck on factory mode https://photos.google.com/photo/AF1Q...nqOsMJaPNKx178 |
11-17-2018, 16:18 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
The Following User Says Thank You to Kirumira For This Useful Post: |
11-19-2018, 08:59 | #3 (permalink) |
Member: 1503666 Status: Offline Thanks Meter: 30 | attached is the log Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:08:19 |
11-19-2018, 09:09 | #4 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Read info from your phone,if same like this i will upload it for you SP7731GEA_IT1408_itel_it1408C_5.1_IT1408-W404-20160902_itel_it1408 |
11-19-2018, 10:46 | #5 (permalink) | |
Member: 1503666 Status: Offline Thanks Meter: 30 | Quote:
Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_it1408C Model Brand : Itel Model Device: itel_it1408C AndrVersion : 5.1 BaseBand CPU: SP7731GEA_IT1408 CompileDate : 7/5/2016 3:17:42 AM Project Ver : IT1408-W404-20160705 Model Ext : itel it1408 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:30 i have flashed the set without sucess always stuck on logo then it goes to factory mode | |
11-19-2018, 11:14 | #6 (permalink) |
Member: 1503666 Status: Offline Thanks Meter: 30 | i have flashed the set without sucess always stuck on logo then it goes to factory mode i used this version SP7731GEA_IT1408_itel_it1408C_5.1_IT1408-W404-20160705_itel_it1408 |
11-19-2018, 16:32 | #8 (permalink) | |
Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Test flow passed! Test flow #1 ... Test flow passed! Test flow #2 ... Test flow passed! Test flow #3 ... Test flow passed! Test flow #4 ... Test flow passed! Test flow #5 ... Test flow passed! Finalize Ok! Test passed successfully! Elapsed: 00:00:24 attached is the log | |
09-29-2022, 10:18 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | There are three IT1408 files at Infinity server, get it https://infinity-box.com/support/ |
