04-28-2009, 09:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | j132 ips unlock done another ps unable to unlock COM41 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090428-143548.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 86 sec Remove/Install battery now ! |
04-28-2009, 09:52 | #2 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | here is log which one i cant unlock \ COM41 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 52 sec Remove/Install battery now ! |
The Following User Says Thank You to unlock & flash For This Useful Post: |
04-28-2009, 10:19 | #7 (permalink) | |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Quote:
04-28-2009, 10:32 | #11 (permalink) | |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | Quote:
try to also fg port but same problem COM15 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... rom version: 0502 booting... finalizing... Boot fail error: operation failed Finished, time used: 66 sec Remove/Install battery now ! | |
04-28-2009, 11:06 | #13 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | your cable is ok .Check with setool if same problem than you can unlock it with setool with 2 credits. if you want to check CPU version than Dissamble the phone and see difrence between unlocked phone and locked. BR NADIR |
04-28-2009, 11:27 | #14 (permalink) | |
problem also with setool v0.915016/UNI CARD SERIAL: 00053310 Loaded 51 flash descriptors PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 17 secs. | |
can flash 6085 in to another supported phone to unlock like 6151 to 6233 ? | oOXTCOo | UID - Box | 5 | 09-14-2007 18:24 |
to Lead - 8138 v106+ (R) unable to unlock ? | Svetli | Cruiser Suite | 5 | 04-08-2005 16:53 |
C45 multiple lock; unable to unlock | vampire | x1x to x45/x50 | 1 | 09-17-2002 19:51 |
unable to unlock t28 | jokkergsm | Old Ericsson Phones & Sony Phones | 0 | 06-27-2002 17:22 |
I was unable to unlock Z5 with version 6.7.1/1SAT | sat | Sony | 2 | 01-18-2002 16:47 |
