05-29-2009, 13:18 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PAKISTAN
Member: 833620 Status: Offline Sonork: 100.1586892 Thanks Meter: 259 | j132 unlock sucsees...... module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090529-171539.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 107 sec Remove/Install battery now ! |
The Following User Says Thank You to AYAZ42 For This Useful Post: |
05-29-2009, 21:57 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
w995 unlock sucsees | apiruk | SETool2 | 6 | 08-27-2009 00:33 |
............e65........... Unlock sucsees | AYAZ42 | Universalbox | 2 | 07-30-2009 23:21 |
5310b unlock sucsees | AYAZ42 | Universalbox | 1 | 06-24-2009 13:07 |
N 95 8 gb unlock sucsees | AYAZ42 | Universalbox | 3 | 06-18-2009 12:57 |
zong unlock sucsees | AYAZ42 | Infinity-Box | 2 | 05-06-2009 19:41 |
