11-29-2018, 03:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | J7 Pro Clone Samsung Logo Only Done by CM2 Open CM2 Select Service Click Identify And Format / Rest Setting din Wait po Logs Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A3C892A0C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3C892A0C9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x53495E168A5880BE5862B966582FE387 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! Finish Product |
The Following 3 Users Say Thank You to fertxter For This Useful Post: |
11-30-2018, 00:16 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
