02-23-2016, 12:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | JayDi Sir I have problem with CM2 software, after repair imei phone stuck in ATE Signaling Test mode, i cant quit this mode without remove battery, new Chinese clone phone's battery difficult to remove. please add reboot normal mode after repair security or any solution?? |
The Following User Says Thank You to thushdt For This Useful Post: |
02-24-2016, 07:42 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Need more details about Phone model, cpu, etc. and log. Press power key for long time, should switch off phone. Br. Infinity Box Support Team. |
02-24-2016, 09:39 | #3 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Code: Start at : [2/24/2016 / 9:39:27 AM] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A0611A42B3249 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473A0611A42B3249 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : SM-G9200 ProdModel : SM-G9200 Device : SM-G9200 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 EXTRA : LCD [0] : ili9806e_fwvga_vdo_dsi LCD [1] : nt35512_dsi_vdo LCD Res : 854x480 TOUCH [0] : GT9XX TOUCH [1] : ft6x06 CAM [0] : gs5604mipi_yuv CAM [1] : ov5645_pip_yuv CAM [2] : ov2655_yuv CAM [3] : gc2155mipi_yuv CAM [4] : ov7695_yuv CAM [5] : gc0308_yuv MODEM : lightning72_wet_jb3_hspa LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR fa_IR sl_SI pl_PL hi_IN ca_ES sv_SE da_DK fi_FI hr_HR sr_RS hdpi Done! Elapsed: 00:00:28 Reconnect Power/Cable! i faced this problem before, not only this phone |
