08-19-2008, 12:50 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Problem Solve Thanx infinity Team here is Test Report COM4 [VCP0] selected Device: Sony-Ericsson K200i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AA008 version sw: CXC1250827 version flex: CDA102772/1 imei: 35617701163967 Check hardware done Read data... reading Sony-Ericsson K200i_35617701163967_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35617701163967_eeprom_calibration-1_20080819-171517.80E.bin reading Sony-Ericsson K200i_35617701163967_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35617701163967_eeprom_calibration-2_20080819-171527.80E.bin reading Sony-Ericsson K200i_35617701163967_ffs... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35617701163967_ffs_20080819-172123.80E.bin Read data done Check data... Check data done Writing... Area: Eeprom flash: 01227E22212200:46237300000000 Write: Eeprom Writing done Finished, time used: 751 sec Remove/Install battery now ! after Write EEPROM set is on "inactive Sim" i unlock it Now OK thanx infinity Support |
08-19-2008, 12:53 | #3 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | after Write EEPROM set is on "inactive Sim" i unlock it Now Set is OK but when i go Setting>Sound Alerts>Ringtones set is very slow work & Hang Help Infinity Plz |
08-20-2008, 08:27 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @InfinitySupport thanx for ur reply i tried to reset default settings via phone menu. but still same i try to reset default settings via Infinity erevry thing is Ok but again Camera Could Not Save pic i download new EEPROM Form Support & Write it,Problem Solve here is EEPROM best regards ALI |
The Following 5 Users Say Thank You to ..::Angel::.. For This Useful Post: |
09-29-2008, 22:27 | #7 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
thanks ........working for me 100%. after write eeprom not need to reset settings & format ffs. COM7 [VCP0] selected Device: Sony-Ericsson-K200i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AB003 version sw: CXC1250827 version flex: CDA102772/1 imei: 35617701165518 Check hardware done Read data... reading Sony-Ericsson-K200i_35617701165518_eeprom_calibration-1... file saved: C:\Documents and Settings\Khadim Hussain\Desktop\Sony-Ericsson-K200i_35617701165518_eeprom_calibration-1_20080929-030932.80E.bin reading Sony-Ericsson-K200i_35617701165518_eeprom_calibration-2... file saved: C:\Documents and Settings\Khadim Hussain\Desktop\Sony-Ericsson-K200i_35617701165518_eeprom_calibration-2_20080929-030944.80E.bin reading Sony-Ericsson-K200i_35617701165518_ffs... file saved: C:\Documents and Settings\Khadim Hussain\Desktop\Sony-Ericsson-K200i_35617701165518_ffs_20080929-031717.80E.bin Read data done Check data... Check data done Writing... Area: Eeprom flash: 01227E22212200:46237300000000 Write: Eeprom Writing done Finished, time used: 912 sec Remove/Install battery now ! | |
The Following User Says Thank You to khadim100 For This Useful Post: |
10-02-2008, 14:56 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | COM4 [VCP0] selected Device: Sony-Ericsson K200i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 01227E24642200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AA008 version sw: CXC1250827 version flex: CDA102772/1 imei: 35234831163874 Check hardware done Read data... reading Sony-Ericsson K200i_35234831163874_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35234831163874_eeprom_calibration-1_20080819-171517.80E.bin reading Sony-Ericsson K200i_35234831163874_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35234831163874_eeprom_calibration-2_20080819-171527.80E.bin reading Sony-Ericsson K200i_35234831163874_ffs... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K200i_35234831163874_ffs_20080819-172123.80E.bin Read data done Check data... Check data done Writing... Area: Eeprom flash: 01227E24642200:92EA0000000000 Write: Eeprom Writing done Finished, time used: 752 sec Remove/Install battery now ! after all u have to change imei 100% perfact saloution thnx in advance br yasermalik |
k220i and k200, camera not save | nawer | Infinity-Box | 47 | 01-10-2012 13:33 |
<<< K200i Camera -- Could Not Save. problem slove 100% >>> | khadim100 | Infinity-Box | 17 | 09-18-2010 08:55 |
Could not read username | GSM-STUDENT | SETool2 | 21 | 09-04-2010 21:42 |
K220 camera could not save | Benzee76 | Infinity-Box | 6 | 02-09-2010 16:43 |
download download problem could not save try to contact administrator | arabie | FuriousGold | 2 | 04-20-2009 05:52 |
