03-30-2008, 14:56 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! dont have exactly same flash file on support, but worth to try after full backup following file: flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Nokia-N66-2sim_MY6226_PCB01_GPRS_MT6226_S01.DM200_V009_1_3_M ATRIX_16m_En_Ru_Vn_Th.B0M.bin also one question: did you try format FFS to solve your problem? I am asking because flashing is a last thing to do with faulty chinese phone |
03-30-2008, 15:28 | #3 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 589869 Status: Offline Sonork: 100.1593501 Thanks Meter: 552 | ist time this phone given restart 1st time i'm using super doctor box to doing format then format ok phone was dead then use infinity notpower on.....all work coplete of infinity but not power on................. |
03-30-2008, 15:43 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i still insist on flashing by adviced above flash file. as long as your phone already dead- no point to make backup because you can not use it to repair your phpne anyway |
03-31-2008, 06:25 | #5 (permalink) |
Member: 589869 Status: Offline Sonork: 100.1593501 Thanks Meter: 552 | COM10 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:9DC1:BF5E high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C9FE0312.[MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_56.BIN_C37511 97].rpl identification#1 detection finished device-id: C9FE0312 identification#1 protocol ver: 04 ver. sw1: MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_56.BIN ver. sw2: V20.56, 68EE8A3C ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 89880F00010001:89880F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 89880F00010001:89880F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _C9FE0312_MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_56. BIN_C3751197_20080331-112407.B0X.bin Finished, time used: 155 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-31-2008, 09:30 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what is this log? why there is MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_56 software version in phone? which version is original? mentioned above or: my6226_pcb01_gprs_mt6226_s01.dm200_v009_1_3_win |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
i need kp135 flash file [USER REQUEST] | sameenshah123 | PolarBox 3 | 5 | 03-29-2010 16:08 |
i need 1650 flash file without games | med26 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-29-2010 11:11 |
Nktel flash file | sameera | Infinity-Box | 3 | 12-20-2008 22:38 |
