Old 07-29-2009, 04:05   #1 (permalink)
Crazy Poster
Member: 395785
Thanks Meter: 20
Red face E71i DEAD TO HELP WITH TRYING TO REPAIR WITH FULL COPY OF FLASH
Help infinity team E71i have died while trying to flash with a flash back of another mobile or reference the same copy of the receiving mobile
==== log: [28/07/2009 09:16:15 p.m.] ====
COM3 [VCP0] selected
module v2.85
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
security area recalculation disabled
write: Firmware
K209M00_PCB01_GPRS_MT6225_S00.M_RK2090405_M28202_V 1_5_0_0M0514__fullflash_20090728-202056.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot Off
chip: 0001:9403:0002
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
.damaged firmware
.damaged hardware
ffs address can not be detected, value from database assigned: 00000000/00000001
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 00000000:00002000
Write Fail
Finished, time used: 303 sec
Old 07-29-2009, 20:38   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we will fix this bug in next CHinese Miracle module which will be released tomorrow.
you can also use some older CM, for example 2,84
Old 07-30-2009, 01:58   #3 (permalink)
Crazy Poster
Member: 395785
Thanks Meter: 20
With the new version 2.86 I get the same error writing
Tion problem is the motherboard of the mobile?
==== log: [29/07/2009 07:20:04 a.m.] ====
module v2.86
advanced flash detection disabled
write: Firmware
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb
Initialize Done
Set baud ...
slowest
Set baud Done
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Archivos de programa\InfinityBox\ChineseMiracle\operation.log
2. C:\Archivos de programa\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx. bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
.damaged firmware
.damaged hardware
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00F40000
Detected ffs/eeprom address is non-standard: 00F40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00F40000
detecting ffs/eeprom size...
ffs/eeprom size: 000C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00F40000-00FFFFFF
detecting firmware version...
done
warning: can not detect firmware version
if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
firmware build: 200906201328
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Fr Es It Tr Farsi Pt Ar
reading: _ffs...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\_ffs_20090729-073031.B0E.bin
Write ...
.damaged firmware
.damaged hardware
ffs address can not be detected, value from database assigned: 00F40000/000C0000
security area (code #1) check...
security area (code #1) fixed
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
error: unexpected termination/freez: 00000000
Write Fail
Finished, time used: 892 sec
Remove/Install battery now !
Old 07-30-2009, 21:50   #4 (permalink)
Member: 148515
hello!
try version 2,87, it will work for sure
Old 07-30-2009, 23:19   #5 (permalink)
Member: 178272
Thanks Meter: 93
Pin on e71i pleas give a hea!
Old 08-01-2009, 04:53   #6 (permalink)
Crazy Poster
Member: 395785
Thanks Meter: 20
hello!
ok thkz 100%%%%%%%%%%%%%%%%%% Full
Zte a712 copy of flash for support !!! bachatia Infinity-Box 2 04-02-2010 03:34
Help, When trying to Flash/Read Lobster S621,... GSMAlleyWay Infinity-Box 16 03-19-2009 19:06
HELP PLEASE Trying to Unlock K800i with D-Client nathank800i D-Unlock Suite 6 04-10-2008 14:42
HELP ME! - Trying to flash 6280 gennyl Nokia Base Band 5 ( BB-5 ) 1 09-09-2007 10:37
Plss help , I tried to change imei with wintesla on 5110 5.22 , now ... Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-11-2000 23:26
Page generated in 0.21237 seconds with 9 queries
