03-20-2009, 00:02 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | KF600 Not working with Pana01 v1.64 Please Infinity Team correct this bug. With v1.64 Code: COM5 [VCP0] selected module v1.64 Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes error: not locked or unknown eeprom Check memory Failed Finished, time used: 42 sec Remove/Install battery now ! Code: COM5 [VCP0] selected module v1.58 Device: LG-KF600 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\LG-KF600_eeprom-static_20090319-185416.B1E.bin loading data... data loaded imei: 01143700425963700 backup critical area Done Check memory ... loading data... data loaded code: 91208566 code: 0000000000000000 Finished, time used: 22 sec Remove/Install battery now ! |
Bird F301 not boot with pana01. | Celhack | Infinity-Box | 0 | 01-28-2010 15:46 |
Still on Pana01 V1.64 update | mohammed ako | Infinity-Box | 1 | 03-22-2009 18:22 |
8150 not working with latest v1.0.0.2247 | snake | FuriouS II | 2 | 04-28-2006 12:23 |
