06-23-2010, 10:35 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Kg-195 blink just (lg) Here is FLASHING LOG. COM4 [VCP0] selected module v3.44 Device: LG-KG195 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware KG195P64-ESA-V10e-XXX-XX_OCT-31-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D_En_Ml_Id_Vn_Th_Cn.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:4F41:5A0C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D.BIN project-id: 7S7332AA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... Area: Firmware flash: 98004900000002:29EA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 6 min 13 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-23-2010, 11:16 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Did you tried this ? C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt |
Nok2Phone v3.12 just released | Cyber_Cracker | GSM Mobile Links | 1 | 12-08-2001 05:09 |
Just have a look at ... | frenchcortex | GSM Mobile Links | 0 | 08-06-2001 18:54 |
NOKIA 3210 V6.0 Nothing on display - just light | mobitech | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-13-2001 23:49 |
LaLGsm, just forgot to say Commercial site! | lotfi17 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-17-2001 13:13 |
