07-29-2009, 10:21 | #1 (permalink) |
Crazy Poster Join Date: Jun 2004 Age: 44
Member: 68763 Status: Offline Thanks Meter: 1 | kg130 not imei change Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 35148320******* current otp imei: 355311011124965 file saved: C:\Program Files\InfinityBox\LgA\eeprom_351483209345761_LG-KG130_20090729-121201.B1E.bin ....... version: 204-16V10a31KG130P40FL Check flash Done Check space ... current eeprom imei: 3514832****** Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 32 sec Remove/Install battery now ! *#06# current otp imei: 355311011124965 not change imei |
F480 Not imei change Big problem new version!!! | volkangsm | UST Pro II | 7 | 04-12-2011 13:06 |
lg kg130 not change ımei pls help me | RaSkAl01 | FuriousGold | 0 | 09-17-2008 08:23 |
U700 unlock ok, can not imei change help pls Elco | galerinisan | NSPRO | 3 | 05-05-2008 19:11 |
dct4+ imei change is not workingis not | selfbox | Universalbox | 0 | 10-02-2007 21:17 |
a200 panasonic not imei change helpppppppppppppppppppp | tatarabraham63 | Infinity-Box | 1 | 04-27-2007 17:38 |
