03-18-2009, 11:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | KG290 flash error Set was restarting with sim. ==== log: [3/18/2009 2:44:23 PM] ==== COM8 [VCP0] selected module v1.37 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 3574560176***** file saved: D:\Documents and Settings\G.Murtaza\Desktop\eeprom_3574560176*****_ LG-KG290_20090318-144454.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 01020000:00020000 error: no any expected answer error: flash write error: 01020000:00020000 Write Fail Finished, time used: 109 sec Remove/Install battery now ! |
03-18-2009, 11:04 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, download and install LgA v1.22 or v1.24 module from /software/archive folder and flash phone again. |
03-18-2009, 18:21 | #4 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Now Facing this Problem COM8 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 3574560176***** file saved: D:\Program Files\InfinityBox\LGA\backup_eeprom_3574560176**** *_LG KG290_20090318-215722.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail error: wrong answer[C5] Finished, time used: 1150 sec Remove/Install battery now ! |
03-18-2009, 18:54 | #5 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Flashing log with other version COM8 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 3574560176***** file saved: D:\Program Files\InfinityBox\LGA\backup_eeprom_3574560176**** *_LG KG290_20090318-222418.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail error: wrong answer[C5] Finished, time used: 1760 sec Remove/Install battery now ! |
LG - KG290 flashing error | Dilip_Nath | Infinity-Box | 33 | 03-11-2011 18:57 |
LG KG290 Flashing Error | ARS.Rehman | Infinity-Box | 9 | 04-08-2009 13:34 |
kg290 flash error with infinity | zeeshan tayyab | Infinity-Box | 1 | 02-18-2009 19:54 |
kg290 flashing error | faizan15 | Infinity-Box | 3 | 01-10-2009 14:41 |
Kg290 flashing error | oMeR_Rasheed | Infinity-Box | 3 | 01-10-2009 14:19 |
