11-13-2008, 17:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | KG290 IMEI Change Problem ! in software imei show changed but when i put sim card and power on Set type*#06# its original imei not change ! is there any solution in infinity ....! |
06-04-2009, 15:18 | #8 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | infinity yes support kg290 and kp260 full imei and unlock...process by WILUNLOCK...thx infinity box... log operation http://forum.gsmhosting.com/vbb/show...44&postcount=2 |
06-04-2009, 15:30 | #9 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: In Your Heart >:)
Member: 952440 Status: Offline Sonork: 100.1581847 Thanks Meter: 1,870 | Quote:
06-04-2009, 16:22 | #14 (permalink) |
Member: 726741 Status: Offline Thanks Meter: 1,256 | friend when I say that the infinity of kg290 IMEI if it is that you do, as I have tested whether the log tubiera show ... it is the same as kp260 and kp260 .... has the same contentious shows the process list, but in reality the IMEI is still the same, why is another process in order to repair the IMEI ... and 2 modules are needed to infinity pana01.exe and LgA.exe ... br WILUNLOCK |
06-04-2009, 20:37 | #15 (permalink) | |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Quote:
kg 110 kg 290 perfect imei change with out any problem with vyjis tool box ..::S@JID::.. | |
kg290 imei change [SOLVED] | RaSkAl01 | FuriousGold | 3 | 06-06-2009 13:43 |
kg290 imei changing problem | khurram_player | Infinity-Box | 2 | 06-04-2009 12:57 |
kg290 imei repair problem | sajidashraf | Infinity-Box | 0 | 02-28-2009 22:30 |
LG-KG290 IMEI Repair problem .. | sajidashraf | Infinity-Box | 0 | 02-27-2009 21:10 |
kg290 imei change | ELPEZ | ULT PRO | 0 | 01-03-2008 01:00 |
