12-20-2007, 20:55 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | kindly assit to installl infinity ----------Process started:1:14:14 AM---------- Locating Emeralda server... Emeralda server address found. Connecting to Emeralda server... Connection to server failed: Socket Error # 10060 Connection timed out.. kindly tell me step by step how to install... i am trying to install ,,, but not happening here is the install. 1. installed infinty setup 2.10a 2. installed infinity box driver 2.14 3. restart pc 4. installed C:\Program Files\InfinityBox\Drivers\box\e- gate_W2k_XP_Vista 5 restart 6. Connect box to PC USB port and select drivers: x:\Program Files\InfinityBox\Drivers\Box\FTDI. then restart..after all this procedure same error 10060. kindly assist me where i am wrong. regards! |
12-20-2007, 21:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is step-by-step installation instruction: http://www.infinity-box.biz/index.php?id=support You must download latest "Dongle" manager from above link. If the same problem still exist (Socket Error # 10060) you need to check that you have active Internect connection and disable firewall so our DongleManager can connect to required server. |
12-20-2007, 21:47 | #3 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | thanks for ue response.. i had to uninstall jaf. the only able to install infinnity.. well when try to register here is the log Locating Emeralda server... Emeralda server address found. Connecting to Emeralda server... Server connection successfully established. S/N: 38A5****, Firmware: 01**.** Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date. Don't try more. need ur assit and plz tell me can jaf and infinity work together or i have to un install jaf work on infinity. regards! |
12-20-2007, 23:26 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I need to know firmware version and your dongle S/N to check what is the problem. Pls send this log with real data to [email protected] I don't see any reason why Infinity can't work together with other boxes. What exactly was wrong when JAF was installed and what exactly become Ok after you uninstall it ? |
kindly assit, MX KEY WILL DAMAGE MY P- KEY | syed.n | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 11-10-2009 09:36 |
M-Star GSM CDMA .. kindly assit! | syed.n | Infinity-Box | 3 | 12-04-2008 00:41 |
Kindly Request To Open This Post | chiragp | Board, Server and Login Problems/Support | 3 | 07-24-2008 06:42 |
Can anyone kind enough to send me the WinDPP v2.22 with the dll file. | xpmobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-03-2002 19:19 |
Can anyone kind enough to send me the WinDPP v2.22 with the dll file. | xpmobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-03-2002 15:18 |
