05-29-2009, 15:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | kp100 unlock problem? Code: COM3 [VCP0] selected module v1.66 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090530-054816.B1E.bin loading data... data loaded imei: 35588202402353500 reading eeprom-security_35588202402353500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202402353500_20090530-054817.B1E.bin reading eeprom-complete_35588202402353500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202402353500_20090530-054823.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 38 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KP100FL-01-V10d-404-83-SEP-30-2008+0 original imei: 35588202402353500 new imei: 35588202402353 imei verification Ok Done Finished |
05-29-2009, 15:55 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Restore Original IMEI after unlock that you have done. If you still face problem here is simple tested process- Flash with the file "KP100-04-FL-49-V10a_262-07_FEB-12-2008+2_En_De_Es_Fr_firmware_lp.B1M" and then make SP Unlock process with option Read Unlock Code. Restart phone with any SIM and enter unlock code readed by Infinity Box. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
05-29-2009, 17:09 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | kp100 unlock just flash ur fone with this flash file nd use unlock methoed airtel KP100-04-FL-49-V10a_262-07_FEB-12-2008+2_En_De_Es_Fr_firmware_lp[1].B1M 10000000% tested if u using kf300 cable u have press nd hold power button br yasermalik |
05-31-2009, 15:52 | #8 (permalink) | |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | Quote:
thanks .... | |
kp100 unlock problem | abumu3ed | FuriousGold | 9 | 03-26-2011 11:25 |
kp100 unlock problem | sonetek | FuriousGold | 6 | 12-17-2009 14:17 |
KP100 unlock problem help | T0T0 | FuriousGold | 5 | 05-27-2009 17:40 |
LG KP100 unlock problem | msashami | Infinity-Box | 1 | 09-02-2008 12:04 |
KP100 unlock problem | PEREPELKINE | VygisToolbox | 5 | 08-05-2008 17:44 |
