06-20-2010, 18:06
#1 (permalink)
Member: 673661
Thanks Meter: 349 | kp170 unlock problem the phone is inder test Quote:
Loading data, wait...
[Infinity Box] v1.39
S/N: 5D75:0112
Wait...
Device: LG-KP170 (under test)
Done
Testing COM3 at 921600...
==== log: [20/06/2010 17:17:09] ====
COM3 [VCP0] selected
module v1.39
Checking data, wait...
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 350305260000001
file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100620-171734.B1E.bin
Check flash Done
Check space ...
warning: Probably wrong model selected or unknown eeprom structure,
Are you sure you want to continue ?
finalization done
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 106 sec
Remove/Install battery now !
| after unlock the phone stil locked i unlock the phone with furious gold but no network Quote:
COM11 [VCP0] selected
module v1.39
Action: flash write
Skip: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100620-173227.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Finished, time used: 35 sec
| but after restore eeprom the phone work fine |
