04-07-2010, 07:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | KP320 Flashing Problem please check the Log i already sent the newer flash file from you people: Code: COM9 [VCP2] selected module v3.32 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610AA00-001-R1D detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1D.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN project-id: 7S7610AA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.32, database date: 04.04.2010): A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 3 min 46 sec Remove/Install battery now ! |
04-10-2010, 23:48 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,956 | Hello, This kind of problems Code: error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Please, double check phone battery voltage and try to flash phone once again. |
04-12-2010, 05:40 | #5 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post: |
04-19-2010, 15:36 | #7 (permalink) |
Banned Join Date: Jun 2009
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | Hi , Phone come dead and want flash but give this error. All precation told by you is normal. 28GB space in disk and bettry full. any idea now. And with chines mircle also same problem. COM9 [VCP0] selected module v3.10 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610SA00-002-R1C detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN project-id: 7S7610SA00-002-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 1 min 3 sec Remove/Install battery now ! Thanks Br, Raja |
04-20-2010, 12:34 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,956 | Hello, Try to use another firmware for flashing. What is the results ? Also, as I can see, DA_DEVICE_NOT_FOUND problem in most cases is a result of empty battery. Please, double check battery voltage. |
05-09-2010, 15:16 | #11 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 37
Member: 199814 Status: Offline Thanks Meter: 1,960 | Using latest version! Quote:
05-15-2010, 09:18 | #15 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1192015 Status: Offline Thanks Meter: 2 | kp320 big error module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 57 sec Remove/Install battery now ! |
n97 flash? - [Problem Solved - April_06_2010] | zulu land | Advance-Box | 4 | 04-06-2010 18:20 |
Lg kp320 camera problem | kay_sera.sera | LG | 0 | 03-10-2010 17:12 |
KP320 flashing error WHAT IS REASON infinity team | sajidashraf | Infinity-Box | 8 | 11-16-2009 13:08 |
KP320 Formating Problem | ZubairArain | Infinity-Box | 3 | 09-30-2009 22:03 |
KP320 Bluetooth Problem, Service Center is changing PCB. Please suggest is PCB NEW? | PkM37 | LG Hardware Repair | 0 | 12-09-2008 15:10 |
