Old 12-14-2008, 13:42   #1 (permalink)
dabdoub2005's Avatar
Member: 188803
Thanks Meter: 4
L342 blinking revived by LgA v1.25
Model selected C3320
flash
AlchemyData downloaded from support
C3320P40-07-V112-000-00_SEP_08_2006AlchemyData.B1P
CodeData downloaded from support too
C3320P40-07-V112-000-00_SEP_08_2006CodeData_w_calibration.B1M
tool used LGA v1.25
Here is the log
COM4 [VCP0] selected
Device: LG C3320
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881500010001:89881500000000
flash: Intel 128MBit-B Strata B 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 356186000673936
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35618600067393 6_LG C3320_20081214-034934.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
flash: 89881500000000:89881500000000
Write Done
Finished, time used: 1021 sec
Remove/Install battery now !
Then I chek
IMEI is ok
Network is ok
Sound is ok
Phone is ok
for those who have the same problem just do as i do and it will be ok
The Following User Says Thank You to dabdoub2005 For This Useful Post:
Old 12-14-2008, 13:52   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
why! flashing support of kg290 is blocked in Lga v1.38 ashrafi580 Infinity-Box 4 06-14-2010 09:02
LGA 1.25 Module Needed maplegsm Infinity-Box 2 01-25-2009 12:11
w810 red blink revive by setool mcjude Sony Ericsson 0 11-12-2008 10:46
did not see LGA V1.25 in support section-help zonetrichur Infinity-Box 1 01-27-2008 07:03
Page generated in 0.20584 seconds with 9 queries
