04-21-2021, 20:23 | #3 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Kenya
Member: 2251589 Status: Offline Thanks Meter: 44 | Spd 9832e locked to safaricom kenya simcard,it unlocks with diag mode and accepts another simcard with full network.but when you attempt to make call it cant it displays a message to put in the safaricom simcard |
The Following User Says Thank You to donpaul For This Useful Post: |
05-31-2021, 13:05 | #5 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: Tanzania
Member: 2239923 Status: Offline Thanks Meter: 48 | Quote:
Card found : XXXXXXXX , v0148 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Operation : Identify [ v2.11 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212-10.0-KE-LC-V019-20201029 MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_18A_W20.23.2_P3_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P3 HW Version: sc9832e_modem CMP_Time : 08-31-2020 19:12:07 MODEM TAG : MOCORTM_18A_W20.23.2_P3_Debug_FM_BASE_18A_W20.23.2 _P3_sc9832e_modem_sharkle_Smart_Phone PSN1 : 059033509Q007740 NVMng : SecurityInfo IMEI[1] : 358265015061093 IMEI[2] : 358265015061093 WIFIMAC : 7895EB33828B BT_MAC : 4045DA00E97F SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:43 Operation : SP Unlock [ v2.11 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212-10.0-KE-LC-V019-20201029 Platform Version: MOCORTM_18A_W20.23.2_P3_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P3 HW Version: sc9832e_modem CMP_Time : 08-31-2020 19:12:07 MODEM TAG : MOCORTM_18A_W20.23.2_P3_Debug_FM_BASE_18A_W20.23.2 _P3_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 358265015061093 IMEI[2] : 358265015061093 WIFIMAC : 7895EB33828B BT_MAC : 4045DA00E97F SEC : SLS:0, SKS:0, SKV:4 SLStatus : 11 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:31 | |
07-17-2021, 21:08 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Hello I will Hijack this thread to enhance it. I could not connect the phone over flashmode, nomatter what Loader I used from 9832e family So, I downloaded the stock firmware from needrom, and booted to flash mode using cm2sp2 here logs: Code: Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L5006S-F3212-10.0-KE-LC-V028-20210625_1633_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L5006S Product Model : itel L5006S Product Name : L5006S Patch Level : QP1A.190711.020 Display ID : L5006S-F3212-10.0-KE-LC-V017-20200811 Ver. Incmt : KE-LC-V017-20200811 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-06-05 Build Time : 11.08.2020 Product Name : F3212 Product Device : itel-L5006S Product Info : L5006S Product Board : L5006S Board Platform : sp9832e Product Manfct : itel Platform Version: MOCORTM_18A_W20.23.2_P1_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P1 HW Version: sc9832e_modem CMP_Time : 07-16-2020 12:08:44 MODEM TAG : MOCORTM_18A_W20.23.2_P1_Debug_FM_BASE_18A_W20.23.2_P1_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:46 Code: Operation : SP Unlock [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L5006S-F3212-10.0-KE-LC-V028-20210625_1633_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 35706826000xxxx IMEI[2] : 35464802000xxxx IMEI[3] : 86740002031xxxx WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:36 flashing logs: Code: Operation : Flash Firmware [ v2.13 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L5006S-F3212-10.0-KE-LC-V028-20210625_1633_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x29 PMTMng : Update PMT Ok! NVRM : sharkle_pubcp_customer_Smart_Phone_nvitem.bin NVMng : Load 0x2F NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 35706826000xxxx IMEI[2] : 35464802000xxxx IMEI[3] : 86740002031xxxx WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x000C5E1C NVMng : Init DST NVMng : Rx29 : Wx28 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : SHARKLE2_DM_DSP.bin CODE : tos-sign.bin CODE : SharkLE_LTEA_DSP_evs_on.bin CODE : cover.img CODE : SC9600_sharkle_pubcp_customer_Smart_Phone_modem.dat FSIMG : cache.img CODE : logo.bmp(1) CODE : sml-sign.bin FSIMG : userdata.img ERASE : METADATA ERASE : UBOOT CODE : sharkle_cm4.bin CODE : logo.bmp FSIMG : socko.img FSIMG : itel.img CODE : recovery.img UBOOT : u-boot-sign.bin CODE : boot.img CODE : gnssmodem.bin CODE : delta_nv.bin CODE : dtbo.img CODE : vbmeta_system.img CODE : vbmeta-sign.img CODE : vbmeta_vendor.img FSIMG : persist.img UBOOT : u-boot-spl-16k-sign.bin ERASE : SYSDUMPDB ERASE : L_RUNTIMENV1 ERASE : MISC CODE : PM_sharkle_cm4_v2.bin FSIMG : super.img ERASE : UBOOT_LOG CODE : prodnv.img CODE : gnssbdmodem.bin FSIMG : odmko.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:20 |
The Following User Says Thank You to yurais For This Useful Post: |
07-17-2021, 21:25 | #8 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | It looks like we need a patched firmware, or an unbranded firmware. I found firmware for Itel l5006c, but am affraid it is also locked to a different carrier L5006c File info in next post... Enviado desde mi SM-N976V mediante Tapatalk |
07-17-2021, 21:28 | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | itel L5006C version: L5006C-F3212-10.0-IN-V029-20210602 – sp9832e_1h10_go Naming is very similar to the l5006s one, so I guess it is the same firmware for a different carrier... Also found this one: L5006-F3212-10.0-ET-V017-20201027 – sp9832e_1h10_go @YellowBoss, you tell me. Last edited by yurais; 07-17-2021 at 21:35. |
07-17-2021, 22:59 | #10 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hello Again Guys As I thought, flashing an unlockedfirmware would solve the issue. I flashed the phone with l5006C firmware, and it is finally unlocked. I still didnt test the phone fully, but Calls, sms, data, ussd, works. the file can be downloaded from needrom dot com logs follows Code: Open : L5006C-F3212-10.0-IN-V029-20210602_1815_user.pac VER : BP_R1.0.0 LEN : 2,27 GiB CPU : sp9832e_1h10 VER : L5006C-F3212-10.0-IN-V029-20210602_1815-user Reading package ... Read package finished! Product Brand : Itel Product Device : L5006C Product Model : itel L5006C Product Name : L5006C Patch Level : QP1A.190711.020 Display ID : L5006C-F3212-10.0-IN-V029-20210602 Ver. Incmt : IN-V029-20210602 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-06-05 Build Time : 02.06.2021 Product Name : F3212 Product Device : itel-L5006C Product Info : L5006C Product Board : L5006C Board Platform : sp9832e Product Manfct : itel Operation : Flash Firmware [ v2.13 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L5006C-F3212-10.0-IN-V029-20210602_1815_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x29 PMTMng : Update PMT Ok! NVRM : sharkle_pubcp_customer_Smart_Phone_nvitem.bin NVMng : Load 0x2F NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 35706826000xxxx IMEI[2] : 35464802000xxxx IMEI[3] : 86740002031xxxx WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x000C5E74 NVMng : Init DST NVMng : Rx29 : Wx28 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : sml-sign.bin CODE : cover.img UBOOT : u-boot-spl-16k-sign.bin ERASE : UBOOT CODE : recovery.img CODE : logo.bmp(1) CODE : prodnv.img CODE : vbmeta_system.img ERASE : METADATA CODE : vbmeta_vendor.img CODE : sharkle_cm4.bin ERASE : MISC FSIMG : userdata.img FSIMG : itel.img FSIMG : cache.img CODE : PM_sharkle_cm4_v2.bin UBOOT : u-boot-sign.bin CODE : dtbo.img FSIMG : socko.img ERASE : L_RUNTIMENV1 CODE : logo.bmp ERASE : UBOOT_LOG CODE : vbmeta-sign.img CODE : SC9600_sharkle_pubcp_customer_Smart_Phone_modem.dat CODE : gnssmodem.bin CODE : tos-sign.bin FSIMG : persist.img CODE : SHARKLE2_DM_DSP.bin CODE : SharkLE_LTEA_DSP_evs_on.bin ERASE : SYSDUMPDB FSIMG : odmko.img CODE : gnssbdmodem.bin CODE : boot.img FSIMG : super.img CODE : delta_nv.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:30 |
The Following 3 Users Say Thank You to yurais For This Useful Post: |
07-18-2021, 07:17 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Thanks for info! BTW - patch on newest Android isn't possible without bootloader unlock, swithc off avb and etc. All props, related to customized android level lock are RO. |
07-20-2021, 22:10 | #12 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | y the way, just wanted to let know,the camera is not working with the firmware used to unlock. I personally tested by rolling back to the stock firmware and camera works back again, after writing again the firmware L5006c, camera stop working. |
10-09-2021, 21:40 | #14 (permalink) | |
Member: 2251589 Status: Offline Thanks Meter: 44 | Quote:
Can you share the file brother | |
