11-13-2008, 12:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | LG KE 770 key unlock code How ? Tried to reset default but still locked ans dont accepting 0000 or 1234 code. please help how to unlock key gaurd lock code ? thanks. here is reset log COM6 [VCP0] selected Device: LG-KE770 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: E:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta_20081113-165953.B1E.bin reading [eeprom-sta2]... file saved: E:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta2_20081113-165956.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... reading [eeprom-complete_35030526000000100]... backup critical area Done Check memory... Check memory Done Write... reset... error: set erase range error: reset failedWrite Failed Finished, Remove/Install battery now ! Time used: 81 sec Last edited by rajumobile; 11-13-2008 at 12:27. |
LG KE 770 Power Switch solution ?? | shahzadthe1 | LG Hardware Repair | 3 | 06-19-2012 05:34 |
Lg ke 770 problem(see here) | ehsas_ghum | Infinity-Box | 8 | 08-29-2010 15:36 |
Lg ke 770 imei change info .. | sajidashraf | Infinity-Box | 3 | 11-18-2009 19:40 |
Lg ke 770 | kash786 | Infinity-Box | 5 | 03-27-2009 07:25 |
lg ke 770 | triyarso | Infinity-Box | 1 | 04-20-2008 20:39 |
