08-18-2008, 09:29 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Indonesia Age: 41
Member: 584778 Status: Offline Thanks Meter: 78 | Lg Ke-820 when flashing Code: COM9 selected Device: LG-KE820 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta_20080818-150855.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta2_20080818-150856.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sec_35030526000000100_20080818-150858.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20080818-150858.B1E.bin backup critical area Done Check memory... Check memory Done Write... Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 990 sec Code: COM9 selected Device: LG-KE820 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta_20080818-152750.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta2_20080818-152752.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sec_35030526000000100_20080818-152752.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20080818-152754.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 23 sec |
lg ke 820 problem is Flash ID(1): FFFF:FFFF FFFF | kakaomar | FuriousGold | 5 | 12-13-2009 12:35 |
Lg ke 820?!! | e2engineer | LG Hardware Repair | 0 | 03-08-2009 15:34 |
lg ke 820 force boot | _iskor_ | VygisToolbox | 0 | 11-24-2008 10:24 |
Ke 820 dead after flash | KingOfGsm | VygisToolbox | 3 | 10-11-2008 16:49 |
KE 820 flasher? | powerman | LG | 0 | 03-12-2007 14:37 |
