lg ke970 error: can't run main loader Lg ke970 hangs at logo, tried several files with fg, infinity and phone still hanged then after a thorough search i came across this solution LG KE970 + KE770 Flasher Tool and Files, flashed phone and it this time never turned on. so i decided to flash it back to its original state using infinity box and this time error booting phone. Wanted to apply this other solution i just met by in forum by SHINE flash LG ke970 without restart problem posted earlier: " testerday i had a ke970 restart when power on i serched on this section but i didn't found the solution. now problem sloved so i want to share the solution may be help other members. 1 full charge the battery before flashing phone 2 i choose thoes files - KE970P40-AFR-V10i-000-00_JUL-30-2007_firmware.B1M - KE970P40-AFR-V10i-000-00_JUL-30-2007_file_system.B1S - KE970_repair_eeprom_complete_10.B1E 3 choose reset setting 4 write languages on this flash are 20: (english,français,deutsch,italiano,portugues,espan ol,turkish,dansk,nederlands,suomi,magyar,norsk,pol ski,roman...) here's the log: COM4 [VCP0] selected module v1.60 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: Eeprom Verifying... Done Write Done Finished, time used: 3480 sec Remove/Install battery now ! Anyone help me revive it module v1.69 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 11 sec Remove/Install battery now ! |
Infinity team help me revive lg ke970 module v1.69 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 11 sec Remove/Install battery now ! |
try to other deviec ..................... |
Can u repair your ke970? I have this problem too. Can u help me? |
What is your phone history ? |
I think its all about wrong flashing specially if tried with gsmmulti ... it will flash ke970 completely but after flashed ur set wont be powered on anymore which was restarting or stuck with lg logo .. and then u cant flash it with any known device even not again with Gsmmulti !!! :( here u may check same thing http://forum.gsmhosting.com/vbb/show...ighlight=ke970 but if we flash it with fg , infinity , z3x problem sometime solved but it will never die like this I cant find any solution for this type of problem which is not boot after flashed with gsmmulti ... yet !!! |
[QUOTE=YellowBoss;5467466]In some cases it's a result of hardware damage. What is your phone history ?[/QUOTE] it is not hardware problem i have a same problem i flashed it with free soft FlashTool_E2_1128_stable(ke970) |
it may be software or hardware. |
Same problem with ke970 ... killed with GsmMulti :( any solution ? Thanks |
If phone can not be connected well with Infinity-Box - we have no solution for this kind of problem. |
[QUOTE = YellowBoss; 5636751]Ce n'est pas moi ont un problème de matériel i même problème il brilla avec Free FlashTool_E2_1128_stable mous (KE970)[/ QUOTE] mai il être un logiciel ou de matériel. [/ QUOTE] infinity box never kill the phone ; I flashed it with infinity box 3 times , & the laste time with free soft , so it is the free soft " flash tool " who has damaged the phone . The size of flash KE970 does not exceed 18 Mo , but the size flash that i downloaded it is 128Mo this is not normal ! |
Hello, All Infinity-Box flash files is packed (f.e. like RAR) and files unpacked on the fly during flash process, it's the reason of small file size. |
The phone can be connected well with Infinity-Box but can't flash it Error Boot |
Hello, What is the problem with flashing exactly ? Post here operation log. |
COM3 [VCP2] selected module v1.76 Device: LG-KE970 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 6 sec Remove/Install battery now ! |
