03-05-2009, 14:04 | #1 (permalink) |
Banned Join Date: May 2003 Location: Heavens
Member: 30124 Status: Offline Sonork: 100.1590000 Thanks Meter: 7,900 | LG-KF600 unlocking module v1.60 Device: LG-KF600 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, time used: 38 sec Remove/Install battery now ! on code read this error accured COM3 [VCP3] selected module v1.60 Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation term arshad mahmood: loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes error: not locked or unknown eeprom Check memory Failed Finished, time used: 41 sec Remove/Install battery now ! on direct unlock show this error plz tell me how i can solve this problem thanks in advance W.B.R Yashaka |
03-08-2009, 12:05 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | If you don't know how just don't give false info, KF600 is supported by Infinity long time ago, working method for unlock is HERE. Next time first read and learn.....then talk... |
03-10-2009, 05:59 | #8 (permalink) | |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Quote:
Use latest version and keep press power. U R PROBLEM SOLOVED | |
LG KF600 Unlock Successfully | Sahil2007 | Infinity-Box | 13 | 12-09-2008 09:45 |
LG KF600 unlock Sucessfully By Micro box | NO.7 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 09-11-2008 11:07 |
lg kf600 unlock help | combocharl | LG | 5 | 09-08-2008 16:57 |
LG KF600 Unlock | jt01934 | LG | 1 | 04-23-2008 16:56 |
