07-05-2010, 13:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | lg kg 285 restart problem here is log plz help team what to do Code: COM7 [VCP0] selected module v1.77 Device: LG-KG285 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL KG288 KG285 P16 ESA V10d XXX-XX OCT 05 2007 +0 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG285_eeprom-static_20100705-175636.B1E.bin loading data... data loaded imei: 35868501424969800 reading eeprom-security_35868501424969800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG285_eeprom-security_35868501424969800_20100705-175637.B1E.bin reading eeprom-complete_35868501424969800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG285_eeprom-complete_35868501424969800_20100705-175643.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 30 sec Remove/Install battery now ! |
07-05-2010, 13:48 | #2 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | i flah this file now set is dead KG288_KG285P16-ESA-V10d_000-00_OCT-05-2007+0_firmware_lp.B1M KG288_KG285-P16-66-V10a_000-00_SEP-04-2007+0_LP_En_Thai.B1P Quote:
07-05-2010, 19:04 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Quote:
Try it or change the firmware. If again problem not solved that means hardware fault. Br. Vijendra Saini | |
The Following User Says Thank You to Vijendra Saini For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
