09-09-2009, 20:14 | #2 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
19 Nov 2006: LG KG110 model supported (Unlock) | InfinitySupport | Infinity-Box | 46 | 04-21-2008 15:33 |
How to install ring tunes for LG KG110 | Fast Unlocker | LG | 31 | 06-25-2007 02:27 |
We are looking for somebody who has LG KG110 in hand! | GSMtricks | Multi-Box | 7 | 04-20-2007 19:05 |
problem unlocking lg kg110 | gsmservices | Infinity-Box | 6 | 01-31-2007 06:50 |
Free Arabic Flashes LG kg110.kg245.kg220 | nano1 | VygisToolbox | 7 | 12-23-2006 13:30 |
