12-16-2009, 16:17 | #1 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 404009 Status: Offline Thanks Meter: 5 | Lg kg195 dead after flash i flash kg195 with new flash files in the support area. after flashing my handset off on LG logo before flashing it was restarting with sim card some time. pleas help me im waiting for your replay. |
12-20-2009, 23:36 | #5 (permalink) | |
How to fix LG KG195, KG200, KG300 freez/restart etc.: 1. Run "ChineseMiracle" software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method 4. repair imei | |
12-22-2009, 12:25 | #7 (permalink) | |
Member: 404009 Status: Offline Thanks Meter: 5 | kg 195 Quote:
sorry not done by this method what to do here is log COM5 [VCP0] selected module v3.02 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: erase NAND flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:0836:2E29 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0A loader: 3.0840.00.00 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 external ram: 00400000 finalize connection... done NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 460800 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... warning: probably flash chip completely erased, no header found nfi area detection finished: failed warning: can not detect chip parameters, default values assigned usb bootloader (chip) is absent Identification Done Write ... formatting... .................................................. ...................................error: code: 6400006900 ...............error: code: A500000000 ...Write Fail Finished, time used: 93 sec Remove/Install battery now ! | |
12-22-2009, 21:44 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Make "format" with this software: http://www.infinity-box.com/download...e_v3.04_v2.rar If phone still can not power-on well after format anf flashing with files from support area you must check phone hardware, f.e. reball/replace both (NOR and NAND) flash chip. |
lg kg195 hang after flash dead | XpErTsGsM | Infinity-Box | 10 | 03-11-2011 12:22 |
plz help .. LG-KG195 dead after flash | mostafa zaki | Infinity-Box | 6 | 06-20-2009 19:47 |
lg 8120 dead after flash | skull | MT-BOX | 1 | 12-05-2005 19:03 |
LG u8180 Dead After Flash with Redbox,Plz Help | citifone | Redbox | 0 | 08-30-2005 06:35 |
LG 8120 Dead after flash | 2stepmaster | LG | 20 | 06-16-2005 07:15 |
