03-23-2009, 08:11 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | cable L4a. method Infinity-Box "Chinese Miracle": How to repair Imei There are several Imei repair methods, if one method failed you need to use other method: === Method-1: use it as a first step to repair Imei cable: use Rx/Tx/Gnd cable or original USB cable from phone package 1. set Imei method to "mode-1" 2. press "Write" button 3. in case of connection problems try to enter in phone service menu and enable COM port according to the next instruction: How to enable COM port for Imei repair procedure: 1. Power-On phone 2. Enter one of the next codes (try one by one): *#110*01# *#3646633# *#3338913# *#42253646633# *#0966# 3. enable COM port: -> Device -> Set UART -> PS -> UART1/115200 4. be sure that phone not in "sleep" mode, LCD light must be On. If LCD is black, shortly press phone "Power" button 5. write Imei === Method-2: use it as a second step to repair Imei cable: use Rx/Tx/Gnd cable 1. set Imei method to "mode-2" 2. press "Write" button === Method-3: use it as last step, also good method for 2nd CPU Imei for Dual-SIM phones cable: use Rx/Tx/Gnd cable 1. set Imei method to "mode-3" 2. press "Write" button |
The Following 2 Users Say Thank You to biochemistali For This Useful Post: |
03-23-2009, 10:31 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Lg Kg200 show only Lg logo... | adnon | SpiderMan | 3 | 03-26-2010 04:16 |
LG KG200 LG LOGO Diaplay Only then Off | ASHRIFF | Infinity-Box | 18 | 10-26-2008 15:14 |
LG KG200 and LG KG300 | adnanskyland | SpiderMan | 2 | 10-10-2008 16:13 |
LG KG200 off on LG startup logo | asad_nomy7 | Infinity-Box | 2 | 04-09-2008 18:45 |
How to Run .jad and .jar files on LG KG200? | umarriaz2k7 | LG | 0 | 02-26-2007 10:56 |
