01-24-2008, 15:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | lg kg270 airtel unlock help plzzz! first unlock [Infinity Box] v1.38 S/N: 388888888 Wait... Current model: LG KG270 Ready COM5 ready Current model: LG KG270 COM5 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10d 404-XX May 18 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080124-182135.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801503652300_20080124-182139.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801503652300_20080124-182148.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 02572213 code: 0000000000000000 Finished, Remove/Install battery now ! Time used: 29 sec read unlock code [Infinity Box] v1.38 S/N: 3888888888888 Wait... Current model: LG KG270 Ready COM5 ready Current model: LG KG270 COM5 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10d 404-XX May 18 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080124-182135.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801503652300_20080124-182139.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801503652300_20080124-182148.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 02572213 code: 0000000000000000 Finished, Remove/Install battery now ! Time used: 29 sec direct unlock method#2 airtel etc [Infinity Box] v1.38 S/N: 388888888 Wait... Current model: LG KG270 Ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10d 404-XX May 18 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080124-182609.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801503652300_20080124-182611.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801503652300_20080124-182619.B1E.bin reading [eeprom-dyn_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35558801503652300_20080124-182621.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 34 sec flash new firmware & language pack KG270P16FL-91-V10c-404-XX-Apr-30-2007+0_Airtel_firmware[1].B1M KG270P16FL-91-V10c-404-XX-Apr-30-2007+0_Airtel_LP_En_Hindi[1].B1P [Infinity Box] v1.38 S/N: 388888888 Wait... Current model: LG KG270 Ready Loading file v.02... KG270P16FL-91-V10c-404-XX-Apr-30-2007+0_Airtel_firmware[1].B1M.bin loaded Loading file v.02... KG270P16FL-91-V10c-404-XX-Apr-30-2007+0_Airtel_LP_En_Hindi[1].B1P.bin loaded COM5 [VCP1] selected Device: LG KG270 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10d 404-XX May 18 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\270\backup_eeprom-sta_20080124-192140.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\270\backup_eeprom-sec_35558801503652300_20080124-192145.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\270\backup_eeprom-complete_35558801503652300_20080124-192155.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 349 sec unlock COM5 [VCP1] selected Device: LG KG270 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10c 404-XX Apr 30 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\sss\backup_eeprom-sta_20080124-192955.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\sss\backup_eeprom-sec_35558801503652300_20080124-193007.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\sss\backup_eeprom-complete_35558801503652300_20080124-193016.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 02572213 code: 0000000000000000 Finished, Remove/Install battery now ! Time used: 37 sec reset to default [Infinity Box] v1.38 S/N: 38A5:010C Wait... Current model: LG KG270 Ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP1] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! error: wrong boot#1: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 13 sec reset to dfault;;; diect unlock method #2 airtel etc Loading data, wait... [Infinity Box] v1.38 S/N: 38A5:010C Wait... Current model: LG KG270 Ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP1] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10c 404-XX Apr 30 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ttt\backup_eeprom-sta_20080124-194415.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\ttt\backup_eeprom-sec_35558801503652300_20080124-194428.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\ttt\backup_eeprom-complete_35558801503652300_20080124-194437.B1E.bin reading [eeprom-dyn_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\ttt\backup_eeprom-complete_35558801503652300_20080124-182619.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 48 sec still no success.. when insert sim card invalid sim! please insert orignal airtel gid a card appears on display regards! |
01-26-2008, 11:19 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. try to flash phone with NON Airtel firmware. 2. check is phone still locked or not if phone is not locked: it's no need to make anything else if phone still locked: make "unlock" procedure |
01-26-2008, 13:57 | #5 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | i have unlocked nearly 2 dozens using direct unlock method #2 (Airtel etc) without facing any problem only IMEI was corrupted and i write back Good Work INFINITY. |
The Following User Says Thank You to mujahid_ali For This Useful Post: |
01-26-2008, 18:01 | #6 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | unlocked successfull 100% flashed with latest firmware KG270P16-ARB-V10f-***-XX-JUL-12-2007_LP[1].B1P.bin KG270P16-ARB-V10f-***-XX-JUL-12-2007_firmware[1].B1M.bin ==== log opened: [1/26/2008 9:35:12 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.38 S/N: 38888888 Wait... Current model: LG KG270 Ready Loading file v.02... KG270P16-ARB-V10f-***-XX-JUL-12-2007_firmware[1].B1M.bin loaded Loading file v.02... KG270P16-ARB-V10f-***-XX-JUL-12-2007_LP[1].B1P.bin loaded COM5 [VCP0] selected Device: LG KG270 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10c 404-XX Apr 30 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\uuuuu\backup_eeprom-sta_20080126-213730.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801503652300_20080126-213742.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801503652300_20080126-213749.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 367 sec sp unlock Current model: LG KG270 Ready COM5 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ARB V10f ***-XX Jul 12 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\uuuuu\backup_eeprom-sta_20080126-215237.B1E.bin loading data... data loaded imei: 35558801503652300 reading [eeprom-sec_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\uuuuu\backup_eeprom-sec_35558801503652300_20080126-215242.B1E.bin reading [eeprom-complete_35558801503652300]... file saved: C:\Program Files\InfinityBox\Pana01\uuuuu\backup_eeprom-complete_35558801503652300_20080126-215251.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 02572213 code: 0000000000000000 Finished, Remove/Install battery now ! Time used: 30 sec then when switch on the set INSERTT CORRECT SIM CARD DISPLAY ON THE SCREEN. THEN i followed this instruction Phone is locked but does not as to enter code: 1. insert any wrong Sim-Card in phone 2. you will see on LCD: "insert correct sim" 3. type unlocking code and press Call "Green" button 4. wait for few seconds - phone will restart and unlocked unlocked ok. infinity team never dissappointed me. best regards! |
hi lg ku800 black unlock help | cellman899 | VygisToolbox | 5 | 12-25-2008 11:49 |
LG KU380 Cannot Unlock, Help | citifone | VygisToolbox | 1 | 04-29-2008 00:24 |
LG U8380 v10d unlock, help!!! | cold_wave87 | LG | 3 | 03-08-2006 17:21 |
LG 3G U8380 Unlock Help! | boy46 | LG | 3 | 11-12-2005 01:43 |
l need lg l 3100 unlock help me | webiso | LG | 2 | 02-26-2005 21:35 |
