Old 05-28-2008, 18:35   #1 (permalink)
Member: 199814
Thanks Meter: 1,960
LG KG270 Using pinfinder now unable to connect
Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe
Loading data, wait...
[Infinity Box] v1.47
S/N: 4389:010E
Wait...
Current model: LG KG270
Ready
Loadng data, wait...
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Read info...
software version: KG270P16-92-V10e-***-XX-JUN 20 2007+0
imei: 35744601822350700
Done
Finished
Loading file v.02...
KG270P16-ESA-V10b-***-XX-Apr-17-2007+0_firmware.B1M.bin loaded
KG270P16-ESA-V10b-***-XX-Apr-17-2007+0_LP_En_Th_Indonesia.B1P.bin loaded
COM10 [VCP0] selected
Device: LG KG270
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
flash chip supported
sw version: ULC2GL KG270 P16 92 V10e ***-XX Jun 20 2007 +0
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-sta_20080528-184113.B1E.bin
loading data...
data loaded
reading [eeprom-sec_35744601822350700]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-sec_35744601822350700_20080528-184118.B1E.bin
reading [eeprom-complete_35744601822350700]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-complete_35744601822350700_20080528-184126.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: Firmware
Writing: Firmware
At this moment power droped of computer so unable to get back in same status gettin problem in conectivy.'
Old 05-28-2008, 19:04   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Check battery voltage, charge it with external power supply and repeat flash process.
In case of problems post here log, but I think everything should be Ok.
Old 06-02-2008, 13:30   #3 (permalink)
Member: 199814
Thanks Meter: 1,960
Okay i am going to try .... rghit now...
unable to connect kp 199 in lg kp tab sekharsun28 ET-BoX 1 10-02-2011 17:12
Unable to connect LG GD900 via usb Gsm-W VygisToolbox 14 12-17-2009 06:12
cid changed on lg 8110 now unable to flash nokia_dan Cruiser Suite 3 01-16-2006 19:07
Unable to connect using RS-232 Cable ToM@to Sony Ericsson 5 12-07-2004 11:31
MYX1 error while flashing! now unable to connect the phone to the soft??? AE177 SagMaster Team OLD Products 7 09-20-2004 21:14
Page generated in 0.15687 seconds with 9 queries
