07-21-2010, 08:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629860 Status: Offline Thanks Meter: 53 | lg kp100 unlock done but error when insert sim..help code: 22771687...pls tell me what i do? thanks ..bro razi COM12 [VCP0] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL KP100 VODAFONE ES 01 FL 34 V10a 214-01 NOV-06-2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20100721-115033.B1E.bin loading data... data loaded imei: 35947602985201800 reading eeprom-security_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35947602985201800_20100721-115034.B1E.bin reading eeprom-complete_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35947602985201800_20100721-115040.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 22771687 Finished, time used: 22 sec Remove/Install battery now ! then i reset the phone but same result..... COM12 [VCP0] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL KP100 VODAFONE ES 01 FL 34 V10a 214-01 NOV-06-2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20100721-115631.B1E.bin loading data... data loaded imei: 35947602985201800 reading eeprom-security_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35947602985201800_20100721-115632.B1E.bin reading eeprom-complete_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35947602985201800_20100721-115638.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 37 sec Remove/Install battery now |
07-21-2010, 08:33 | #2 (permalink) |
Member: 629860 Status: Offline Thanks Meter: 53 | prob solved by direct unlock method 2 COM12 [VCP0] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL KP100 VODAFONE ES 01 FL 34 V10a 214-01 NOV-06-2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20100721-122813.B1E.bin loading data... data loaded imei: 35947602985201800 reading eeprom-security_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35947602985201800_20100721-122816.B1E.bin reading eeprom-complete_35947602985201800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35947602985201800_20100721-122822.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 27 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to razisamb For This Useful Post: |
09-29-2010, 20:25 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | helped me today i used same method #2 and it worked for me. i have fone with saying sim error here is log COM17 [VCP0] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20100929-122344.B1E.bin loading data... data loaded imei: 35847902197339500 reading eeprom-security_35847902197339500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35847902197339500_20100929-122345.B1E.bin reading eeprom-complete_35847902197339500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35847902197339500_20100929-122351.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 28 sec Remove/Install battery now ! |
The Following User Says Thank You to malikzahidawan For This Useful Post: |
