06-23-2010, 12:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: KHENIFRA MOROCCO
Member: 84034 Status: Offline Thanks Meter: 78 | Lg kp320 .................................................. ... OM4 [VCP1] selected module v3.45 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 1 min 41 sec Remove/Install battery now ! |
06-23-2010, 18:38 | #3 (permalink) |
Member: 84034 Status: Offline Thanks Meter: 78 | I was flash it 3 days ago and working will but after insert MMC the phone powring off itry to reflash it by 3 Ffs in the infinity s suport . Thank s YellowBoss and all |
06-23-2010, 23:58 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, If you was able to flash phone days ago, but now you unable to flash phone - you must double check phone battery voltage and probably you need to check phone hardware. Also be sure that you have enough free space at your PC HDD, you must have at least 256Mb free space for temporary files. |
Service software and flash for LG 200/500/600 | Demon_Ok | LG | 35 | 04-10-2007 00:04 |
LG-500 | questman | LG | 2 | 02-13-2006 14:42 |
Alvatel OT30x Bulgarian LG | Permonik | Alcatel & TCL Old Models | 2 | 02-16-2002 16:56 |
LG-200 Pinout | questman | LG | 2 | 02-15-2002 23:07 |
I need lg with EAAHNIKA for X35 | alruus | x1x to x45/x50 | 0 | 11-22-2001 12:44 |
