05-02-2016, 12:29 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | LG X147 MT6572 [Can I Flash With CM2?.] Is This Model Supported?. Operation : Check / Read Info [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Check / Read Info [ v1.47 ] With Press & Hold Volume Up Key. Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A12DB891FF Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A12DB891FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : ADC3D8CCEB11DC6A938158F6B06AA526 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : lo_1_open_in ProdModel : LG-X147 Device : lo_1 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : LGX147-00-V10e-IND-XXX-FEB-25-2015+0 SECURITY : IMEI_SW [1] : 35347XXXXXXXXXX IMEI_SW [2] : 35347XXXXXXXXXX BTMAC Addr : 344DFXXXXXXX WiFi MAC : 344DFXXXXXXX MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_P7_1_wg_n EXTRA : LCD [0] : otm8018b_wvga_dsi_vdo LCD Res : 800x480 TOUCH [0] : elan3257 CAM [0] : s5k5eayx_yuv CAM [1] : ov2675_mipi_yuv MODEM : lo1_hspa LOCALE : en_US hi_IN ko_KR Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A12DB891FF Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A12DB891FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : ADC3D8CCEB11DC6A938158F6B06AA526 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! Brand : lge ProdName : lo_1_open_in ProdModel : LG-X147 Device : lo_1 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : LGX147-00-V10e-IND-XXX-FEB-25-2015+0 [Read Ok] : preloader_lo1.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / lo1 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1006 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__lge__LG-X147__lo_1__4.4.2__LGX147-00-V10e-IND-XXX-FEB-25-2015+0\ All done! Done! Elapsed: 00:04:55 Reconnect Power/Cable! Operation : Read Flash [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A12DB891FF Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A12DB891FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : ADC3D8CCEB11DC6A938158F6B06AA526 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! Read Ok , collect info Brand : lge ProdName : lo_1_open_in ProdModel : LG-X147 Device : lo_1 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : LGX147-00-V10e-IND-XXX-FEB-25-2015+0 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__LGE__LG-X147__lo_1_open_in__lo_1__LGX147-00-V10e-IND-XXX-FEB-25-2015+0__Android_4.4.2.ispff Done! Elapsed: 00:15:46 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
