lgkg220 flash problum module v1.38 Device: LG-KG220 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 359101006189461 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359101006189461_LG-KG220_20090608-031827.B1E.bin ...... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881500010001:89881500000000 flash: 90009000000000:90909000000000 flash: 90009000000000:90909000000000 flash: 89881500010001:89881500000000 write: 2nd chip area error: no any expected answer error: flash write error: 18000000:00002000 error: no any expected answer error: flash write error: 18000000:00002000 helpe me infinity teem |
Charge your battery and change speed. |
COM4 [VCP1] selected module v1.38 Device: LG-KG220 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb id: 00005258 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 359101006189461 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359101006189461_LG-KG220_20090608-051632.B1E.bin ...... reading _eeprom-ffs_359101006189461... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_359101006189461_LG-KG220_20090608-051936.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... error: no any expected answer error: flash erase error: 18400000 error: no any expected answer error: erase #E2 Erase Fail Finished, time used: 231 sec Remove/Install battery now ! |
How did you solve the same problem there kg220 |
