03-04-2020, 08:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | lgm-x401l da file require Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1836 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1820 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1820 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : V5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Update configuration ... Update Ok! Load IDBase v33127 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
03-04-2020, 08:36 | #4 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | logs from lgs Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Device not found! Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset UserLocks [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? Check cable, battery, connection and drivers! Reconnect Power/Cable! |
