12-31-2008, 11:58 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Lobaster 544 Successfully U nlocked Lobaster 544 Successfully Unlocked................. COM8 [Serial2] selected module v2.54 Device: Lobster-544 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8A01]... CPU: MT6219 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... warning: wrong cs at 0x00E84800, retry... read error recovered file saved: C:\Program Files\InfinityBox\MModule\eeprom_20081225-193911.9AE.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... extra method (auto) in progress... flash: B0001D00000000:B0001D00000000 ................ detect standard fat location pass #1... .................................................. .............. detect extended fat location pass #1... ................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete required area #1 found required area #2 found required area #3 not detected Special operation Done Write ... flash: B0001D00000000:B0001D00000000 Write: lock-area-3 flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 287 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
12-31-2008, 16:38 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
5230 boot display SIM card invalid ATF success with good repair! | 20442044 | Advance-Box | 3 | 06-09-2015 08:56 |
Lobster 544 SUCCESSFULLY UNLOCKED | alamgarh | Infinity-Box | 5 | 06-05-2009 11:31 |
Ùnlock Sagem Myc-2 | moochie | Infineon C16X M51 & ARM7 M52 BASED | 1 | 01-29-2004 18:23 |
LG7020 Nlock | XenKo78 | LG | 0 | 08-19-2003 17:13 |
how to nlock MC 916 help me | Siemens man | Infineon C16X M51 & ARM7 M52 BASED | 0 | 11-13-2001 19:40 |
