01-06-2009, 18:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: UAE
Member: 265104 Status: Offline Sonork: 100.1609402 Thanks Meter: 88 | Huawei-T161L unlock suss module v1.59 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090106-093854.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090106-093855.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090106-093901.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090106-093921.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 67 sec Remove/Install battery now ! |
The Following User Says Thank You to tanha For This Useful Post: |
01-06-2009, 19:02 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Huawei t161L unlock Success | Imran Bhatti | Infinity-Box | 5 | 02-10-2009 22:27 |
huawei t161l unlock done | nadim electro | Infinity-Box | 2 | 01-28-2009 13:50 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
huawei T161L unlock down all network by infinity box | aleem26 | Infinity-Box | 1 | 01-19-2009 15:11 |
Huawei T161L unlocked :D | kasrawiz | Infinity-Box | 2 | 01-16-2009 00:06 |
