Old 10-03-2007, 17:20   #1 (permalink)
Member: 577020
Thanks Meter: 27
maini
HELLO INFINITY MASTERS PLZ HELP I HAVE GTMOBILE TV100 I WILL READ COMPLETE BACKUP AFTER FFS BUT STILL PROBLEM
SET ON ONLY 10 SEC.
Action: NAND reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip-id: 0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND id: 20F1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 0020:00F10080001D [08400000]
warning: NOR flash chip not supported or not detected
Initialize Done
Set baud...
921600
Set baud Done
Identification...
converting data...
done
protocol ver: 04
ver. sw1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN
ver. sw2: MAUI.05C.W06.24.MP.V18
ffs offset/size: 02000000/06000000
id-page Ok
nfi area detection finished: Ok
structure: 2nd [standard] (or higher) generation
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 48 sec
Remove/Install battery now !
ANY SOLUTION INFINITY MASTERS
Old 10-04-2007, 00:41   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
try to make "safe" format
Old 10-04-2007, 08:44   #3 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
i will try safe mode but answer
19200
Initializing[6228:8A02]...
Connecting, wait...
error: can't finalize test moide
Operation failed !
Finished, time used: 27 sec
Old 10-04-2007, 08:50   #4 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
whats the mean
Old 10-04-2007, 09:13   #5 (permalink)
Member: 348451
Thanks Meter: 2
when you use the safe format mode you have to keep pressing the power button untill the phone start powering up
then the softare will tell you to remove your hand
Old 10-04-2007, 10:56   #6 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
SET ON ONLY 10 SEC.
Action: NAND reset
Boot...
19200
Connecting, wait...
chip-id: 0000:0101
Boot Done
Initialize...
version: 3.1
NAND id: 20F1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
Initialize Done
Set baud...
921600
Set baud Done
Identification...
converting data...
done
protocol ver: 04
id-page Ok
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
pls sir need the pinouts of this mobile or cable discription
Old 10-05-2007, 16:22   #7 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
i will try keep pressing but same problem plz help infinity team suggest me
Old 10-06-2007, 17:30   #8 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
i am wating for your reply before two days & i also tried full flashing for three firm..... but my set is dead any solution infinity masters plz help,
Old 10-06-2007, 17:32   #9 (permalink)
Member: 128745
Thanks Meter: 16,936
what was the condition of phone before flashing ?
also have u checked the hardware of the phone ?
Old 10-07-2007, 08:18   #10 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
i will write backup again my set is on but same problem set on only 10 sec
Old 10-07-2007, 09:36   #11 (permalink)
Member: 130995
Pls, make this:
send backup file to [email protected]
also include in your mail information about phone connector and pinout.
We will check your backup and then we will see what to do.
Old 10-11-2007, 09:34   #12 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
CHINEAS o2 A818. 8 PIN CONECTER ........1 GND 8 GND 2RX OR TX 3 RX OR TX
Old 10-11-2007, 09:50   #13 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
did u tried format ffs Complete???????????
Old 10-13-2007, 11:57   #14 (permalink)
Member: 577020
Thanks Meter: 27
Thumbs up maini
i will try complete format but no respon................. condition same any solution.
Old 10-15-2007, 15:26   #15 (permalink)
Member: 185776
Thanks Meter: 73
A818 Gaoxinqi Set Restart Ok
A818 Model phone name GAOXINQI Resatart problem with sim.I read full back up and formate ''safe' condition and setting side 6288 NAND type selected.Pin out keyboard up side 1.......8,1 gnd,2rx,3tx.now working with sim.For first time set get long time to ON.See log.
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v1.56
S/N: xxxxxxxxx
Wait...
Device: Autodetect 6205-6227 NOR
Done
Device: Autodetect 6228 NAND
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: reset settings
Model: Autodetect 6228 NAND
Checking data, wait...
COM3 [VCP0] selected
19200
Connecting, wait...
Phone detected, wait...
Hardware: MT6228,E02
Date: 2004.07.02
Version: 1.0
Version: MAUI.05C.W06.24.MP.V18
Version: MT6228_05C_HW
detecting structure #2...
done
imei: 35081800319882
warning: wrong packet checksum
230 of 235 items cleared
3 items remains
Finished, time used: 54 sec
maini veerpreet Nokia Hardware & Hardware Repair 4 06-16-2008 07:49
maini veerpreet Infinity-Box 1 05-30-2008 14:29
Maini veerpreet Universalbox 0 05-26-2008 18:40
maini veerpreet Nokia Hardware & Hardware Repair 0 05-13-2008 09:17
Page generated in 0.27829 seconds with 10 queries
