12-05-2007, 15:23 | #31 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 577020 Status: Offline Thanks Meter: 27 | maini 15RX 16RX COM3 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MTG30C-multiv01.01b04 Version: G30C_HW detecting structure #2... done imei: 35580800042137 warning: wrong packet checksum warning: wrong packet checksum 167 of 172 items cleared 3 items remains Finished, time used: 32 sec Remove/Install battery now ! maini |
12-05-2007, 18:53 | #32 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello mr.veerpreet! thank you very much for your test report and posted pinout for SED y690!! we will include this information in next pinout update |
12-17-2007, 11:27 | #33 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
I had Bluetooth 2 SIM Y690 It had the following pinout keyboard top 1.........18 COM/RJ45 1,2 - gnd 7 - TX 9 - RX Code: ==== log opened: [17.12.2007 12:18:58] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.10 S/N: 04F1:010C Wait... Device: Autodetect 6205-6227 NOR Done COM5 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:E358:D221 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.3D65EAA5.[E553_Y15DBT799F8_E553_GPRS_MT6226_S01.K799_Y15DBT799F8_01_1.BIN_0F26FA05].rpl New firmware detected: E553_Y15DBT799F8_E553_GPRS_MT6226_S01.K799_Y15DBT799F8_01_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 3D65EAA5 identification#1 protocol ver: 04 ver. sw1: E553_Y15DBT799F8_E553_GPRS_MT6226_S01.K799_Y15DBT799F8_01_1.BIN ver. sw2: K799_Y15DBT799F8.01.1 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... ........................................................ detect extended fat location pass #1... ..................................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok file saved: backup_system_log_3D65EAA5_E553_Y15DBT799F8_E553_GPRS_MT6226_S01.K799_Y15DBT799F8_01_1.BIN_0F26FA05_20071217-122248.B0X.bin Finished, time used: 178 sec Remove/Install battery now ! | |
01-04-2008, 20:00 | #35 (permalink) |
Member: 577020 Status: Offline Thanks Meter: 27 | maini N-95 18 pin conecter 18........9.7....1 7-rx 9tx COM1 selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:4D0B:0F0B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E553_XZY1ARTHRUTR.01.1_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 35110165125278 connection Ok building list... done items to clear: 210 warning: wrong packet cs warning: wrong packet cs 154 of 210 items cleared 0 items remains Finished, time used: 286 sec Remove/Install battery now ! maini |
01-06-2008, 16:33 | #36 (permalink) |
Member: 577020 Status: Offline Thanks Meter: 27 | maini A-950 18 pin conecter 5 rx 6tx COM1 selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:A441:E210 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 092540_669_V0504 Version: TIANYU26_06A_HW detecting structure #2... done 42 byte(s) read imei: 35269250051012 connection Ok detecting structure #1... done 148 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 5454 Finished, time used: 44 sec Remove/Install battery now ! maini enjoy all member |
02-22-2008, 13:17 | #40 (permalink) |
Member: 577020 Status: Offline Thanks Meter: 27 | maini FOR ALL FORUM USERS IMPORTANT NOTES FOR CUSTOMER 1. Before giving handset, please take out your accessories, sim card, memory card and battery. By chance all given objects come with handset and lost we shall not responsible. 2. Please take receipt from counter only. If you give your handset to our technician or any other worker and it lost or any problem occurs, we are not responsible for that. 3. We give only 7 days warranty for problem solved by us. 4. During software installation or unlocking handsets if handset turns dead, the Customer shall be responsible for that. |
03-21-2008, 17:35 | #44 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
If somebody has this file, please, send flash and "backup_system_log..." files to [email protected] so we can upload it in support area. | |
05-10-2008, 09:32 | #45 (permalink) |
Member: 577020 Status: Offline Thanks Meter: 27 | maini successfully unlock w910i se with setool 10 creadit only v0.914028/UNI CARD SERIAL: 000000000 Loaded 51 flash descriptors SERVER SUPPORT ENABLED. ChipID:C802,EMP protocol:0401 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:358************xx CERT:RED LDR:2007-11-16 18:10 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A048 LDR CAPS:SYSTEM FLASH LDR:2007-11-16 18:12 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A048 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Asking for EROM signature... Waiting for calculation process... RESPONSE: "358***************x ADDED TO QUEUE,CHECK BACK LATER" (1) SIGNATURE QUEUED FOR CALCULATION, CHECK BACK LATER signature calculation not done,err: 26 v0.914028/UNI CARD SERIAL: 000000000 Loaded 51 flash descriptors Connecting to UFS... Found 2 FTDI device(s). UFS #75660 READY Closing UFS at your request. SERVER SUPPORT ENABLED. phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 393 secs. SERVER SUPPORT ENABLED. ChipID:C802,EMP protocol:0401 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:358************x CERT:RED Model:W910i MAPP CXC article: R1CA029 prg12009129_HUTCHISON_SH MAPP CXC version: R1CA029 Language Package:HUTCH-WORLD CDA article: 1201-4541 CDA version: R22A Default article: 1200-5451 Default version: R1CA029 PROVIDER: 000-00 Network LOCKED SECURITY UNITS BACKUP CREATED. Elapsed: 4 secs. SERVER SUPPORT ENABLED. ChipID:C802,EMP protocol:0401 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:358***************x CERT:RED LDR:2007-11-16 18:10 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A048 LDR CAPS:SYSTEM FLASH LDR:2007-11-16 18:12 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A048 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Asking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (1038) Backup security data... Erasing locks... DISCONNECT PHONE, FULLY TURN IT ON AND ATTACH AGAIN. BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM11 PHONE READY TO PROCEED. Connecting to server We got a step1 response seed is:00C3BCA7 We got a step3 response signoff response ok Phone succefully unlocked. USERCODE RESET TO "0000" Elapsed: 831 secs. |
maini | veerpreet | Nokia Hardware & Hardware Repair | 4 | 06-16-2008 07:49 |
maini | veerpreet | Infinity-Box | 1 | 05-30-2008 14:29 |
Maini | veerpreet | Universalbox | 0 | 05-26-2008 18:40 |
maini | veerpreet | Nokia Hardware & Hardware Repair | 0 | 05-13-2008 09:17 |
