02-15-2019, 11:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Croatia Age: 48
Member: 9568 Status: Offline Thanks Meter: 209 | MeanIT C1 MT6580 Secure Boot FRP I need to reset FRP on MeanIT C1 smartphone, but without success. Code: Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM147) MODE : PRELOADER PORT PORT : 147 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1836 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_CRYPTO20.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Thank you! |
02-15-2019, 12:09 | #2 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
today my Hollyday Sent from my SM-A710F using Tapatalk | |
02-15-2019, 12:43 | #3 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | @Bmt_HR use latest mtk 2.04 or later select Teksun>>XUNHU_MT6580 from list and repeat what is result ?? |
The Following User Says Thank You to kamal_singla For This Useful Post: |
02-15-2019, 13:53 | #5 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | Quote:
The Following User Says Thank You to SR9 For This Useful Post: |
02-15-2019, 14:04 | #6 (permalink) |
Member: 9568 Status: Offline Thanks Meter: 209 | I solve my problem! Thank you all! Select Teksun>>XUNHU_MT6580 from list and connect with VOL - button pressed |
The Following User Says Thank You to Bmt_HR For This Useful Post: |
02-15-2019, 14:39 | #7 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
if mobile connected in Preloader mode need select DA_SWSEC.bin and if mobile connected in BROM mode need select MTK_AllInOne_DA.bin and by default auth and preloader or internal EMI Last edited by rebainoor; 02-15-2019 at 14:49. | |
