Old 02-04-2016, 08:04   #1 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Smile --Micromax Official tool for removing frp on YU phones for Infinity users--
Hello,
Here is little gift for Infinity product users- Official frp remove tool on Yu phones.
First full process (for Yu-5010 and Yu-5010A)-
-Press volume up key then press power key in power off mode to enter fast boot mode.
-Install adb driver
-Extract software folder on desktop
-Run Unlock.bat file given in software folder.
-Wait for phone to boot up fully, done.
For other YU phones (like Yu-4711)-
-Press volume up key then press power key in power off mode to enter into recovery mode
-Select reboot to Bootloader
-Phone will restart and stuck on YU logo
-Install adb driver-
-Run unlock.bat file from software folder-
-In case if doesn't works then run below commands in CMD window-
Cd desktop\adb
Adb devices
Fastboot   -i   0x2a96   erase config
Fastboot   -i   0x2a96   reboot
-Wait for phone to bootup fully, done
Hope this helps Infinity users.
File uploaded to Infinity support server2/flashfiles/0-CommunityUploads with the name- YU FRP by PBs and will available for download soon.
Br.
Infinity Box Support Team.
The Following 14 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 02-04-2016, 08:31   #2 (permalink)
jorj_saha's Avatar
Member: 1649620
Sonork: 100.1603891
Thanks Meter: 177
Plz video ......................
Old 02-04-2016, 12:41   #3 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
The process is already very simple and explained, only need to click one button- unlock.bat or just write/copy command.
If you still need video for this simple operation it's better to leave it or get it done from someone else who can.
Br.
Infinity box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 02-04-2016, 13:19   #4 (permalink)
rohit.sharma73's Avatar
Member: 2097870
Sonork: FINDING....
Thanks Meter: 65
Yu5010a frp done plzzz next sol solve sir yu4711 frp lock problem plz sol yu4711 frp lock CM2TOOL
Old 02-05-2016, 06:44   #5 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Read my first post few times again and you will get solution.
Br.
Old 02-07-2016, 16:03   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
This package available here also
Old 02-08-2016, 11:03   #7 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Originally Posted by PASSIONATE_BOYS View Post
Hello,
-Install adb driver
Cd desktop\adb
Adb devices
Br.
Hello Bro. I do all steps but handset not power on.
Model is YU5010A. what do next bro.
B.R.,
B.Uttam
Old 02-09-2016, 05:59   #8 (permalink)
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Team i am waiting for your reply.
Thanks,
B.Uttam
Old 02-09-2016, 07:30   #9 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
What have you tried to do? Remove battery for sometime, insert charged battery and try to switch on again. I have personally tested on yu5010A with unlock.bat file and has no problem.
Br.
Old 02-09-2016, 09:22   #10 (permalink)
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Hello,
Br.
OK, i will try & post result Bro. Hope it's work your trick.
B.Uttam
Old 02-09-2016, 10:07   #11 (permalink)
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Hello,
Br.
No luck Bro. i try with full charged battery. Handset not power on.
Thanks,
B.Uttam
Old 02-09-2016, 10:25   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Try this-
Pull the battery out
Plug a good micro usb cable directly into a computer (no hubs/keyboards/monitors/extensions/etc)
hold the volume up button (hard to do with the cover off but it is doable)
Plug the cable into the device (while still holding the button)
put the battery back in (while still holding the button)
if it works it'll boot immediately into fastboot mode without having to hit power.
-Credits to original poster.
If still not power on refer to micromx section of this forum as procedure is official and tested, and this is Infinity Box section so cannot talk much here about unsupported phones by Infinity.
Br.
Old 02-09-2016, 13:09   #13 (permalink)
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Hello,
Try this-
Br.
OK Thanks Bro. I will try and if i am success to recover phone i send u PM.
Thanks,
B.Uttam
Old 02-09-2016, 16:47   #14 (permalink)
jorj_saha's Avatar
Member: 1649620
Sonork: 100.1603891
Thanks Meter: 177
Hello,
-Install adb driver
Cd desktop\adb
Adb devices
Br.
thanks Infinity Box Support Team good working
Old 02-12-2016, 14:00   #15 (permalink)
Member: 893550
Thanks Meter: 139
i tasted
http://www.4shared.com/download/gvO1...f966&lgfp=3000
thanks infinity Team
Page generated in 0.24886 seconds with 8 queries
