09-02-2015, 15:25 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx a91 failed to remove google ac Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00453E4906CF15 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_lcsh77_cu_ics2.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img Brand : micromax ProdName : A91 ProdModel : Micromax A91 Device : A91 AndroidVer: 4.0.4 MTKxCPU : MT6577 MTKxPRJ : ALPS.ICS2.MP.V1 [ScatCFG] : MT6577 / V1.0.0 / lcsh77_cu_ics2 / EMMC FW Size : 423 MiB Scatter saved to : D:\MT6577__micromax__Micromax A91__A91__4.0.4__ALPS.ICS2.MP.V1\ All done! Done! Elapsed: 00:04:55 Reconnect Power/Cable! clear lock but not done Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00453E4906CF15 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00453E4906CF15 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : micromax ProdName : A91 ProdModel : Micromax A91 Device : A91 AndroidVer: 4.0.4 MTKxCPU : MT6577 MTKxPRJ : ALPS.ICS2.MP.V1 Saved to : D:\MT6577__MICROMAX__Micromax_A91__ALPS.ICS2.MP.V1__Android_4.0.4__20130115_172103.ispff Done! Elapsed: 00:27:36 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00453E4906CF15 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
09-02-2015, 15:30 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. It have ancient Android 4.0.x version, as mentioned in Update logs - it will not work with them, until I not found such phone. |
