12-16-2019, 15:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Malawi
Member: 2761624 Status: Offline Thanks Meter: 59 | mobicel astrol firmware read failed Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Mobicel : ASTRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Mobicel : ASTRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
01-18-2020, 21:54 | #3 (permalink) |
Junior Member Join Date: Mar 2017 Location: Honduras Choloma
Member: 2700012 Status: Offline Sonork: 1677348 Thanks Meter: 0 | Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Bmobile_AX1077+_TIGO_LTM_V004 Ver. Incmt : 32515 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-08-05 Build Time : 1565941617 Product Model : AX1077+ Product Brand : Bmobile Product Name : AX1077_MTG06 Product Device : Bmobile_AX1077_MTG06 Product Board : AX1077_MAS Product Manfct : Bmobile Product Info : AX1077+ Product Board : sp9832e_fs097_32b Board Platform : sp9832e UserData : STATE : ENCRYPTION Done! Elapsed: 00:01:03 Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Bmobile : AX1077+ Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Bmobile : AX1077+ Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... ERROR : Baud set failed! Use default! Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
01-19-2020, 15:17 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | In some cases in SS mode loaders device can't be initialized. We are looking for samples and will fix it asap. Hope, next version will fix that in near time. |
