03-26-2019, 19:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | MobiWire Ahiga (Base secured) partial flash done with CM2MT2_V2.05 Code: Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM93) MODE : PRELOADER PORT PORT : 93 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1816 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6572 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064314734A2020504F532D826 DAInf: 4 : 2 : 136 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483447316440502A226D832F5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G1d EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE9000000 [ 3,64 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B2FF3FC8D9FB29E6A0BC0F734B3682 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : KOT49H Display ID : UP16 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 1429347094 Product Model : Ahiga Product Brand : MobiWire Product Name : Ahiga Product Device : Ahiga Product Board : UP16_MobiWire_Ahiga Product Manfct : MOBIWIRE Product Info : up16_h502s_zap USERDATA : PLAIN ( NOT encrypted ) IMEI[0] : 355028xxxxxxxxxx IMEI[1] : 355028xxxxxxxxxx IMEI[2] : 354648xxxxxxxxxx NVRAM check : Passed! Done! Elapsed: 00:00:15 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM93) MODE : PRELOADER PORT PORT : 93 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1816 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6572 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064314734A2020504F532D826 DAInf: 4 : 2 : 136 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483447316440502A226D832F5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G1d EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE9000000 [ 3,64 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B2FF3FC8D9FB29E6A0BC0F734B3682 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : CACHE Format Ok : USRDATA Done! Elapsed: 00:00:30 Reconnect Power/Cable! Card found : C8DD0BBA , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v319103 Ok! Update configuration ... Update Ok! Load IDBase v319103 Ok! Operation : Memory Tool Init [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM93) MODE : PRELOADER PORT PORT : 93 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1836 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6572 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064314734A2020504F532D826 DAInf: 4 : 2 : 136 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483447316440502A226D832F5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G1d EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE9000000 [ 3,64 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B2FF3FC8D9FB29E6A0BC0F734B3682 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Set default path : D:\InfinityBox\CM2MT2_A\phdata\ Ready! Operation Write Memory Write selected partitions [3] [0] Write partition : ANDROID Write from : G:\mobiwire\MT6572__MobiWire__Ahiga__Ahiga__4.4.2__UP16\system.img Write partition Ok! [1] Write partition : CACHE Write from : G:\mobiwire\MT6572__MobiWire__Ahiga__Ahiga__4.4.2__UP16\cache.img Write partition Ok! [2] Write partition : USRDATA Write from : G:\mobiwire\MT6572__MobiWire__Ahiga__Ahiga__4.4.2__UP16\userdata.img Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:03:30 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to rebainoor For This Useful Post: |
03-26-2019, 19:30 | #2 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,104 | SecureDevice : Paired type! -> INFO : That device WILL dead after ReadOut Flashing! -> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available! -> INFO : In most cases you can "unsecure" device in Engineer mode flash file will be in infinity support soon MT6572__MOBIWIRE__Ahiga__4.4.2__UP16__KOT49H__up16 _h502s_zap |
The Following 5 Users Say Thank You to rebainoor For This Useful Post: |
04-01-2019, 11:37 | #3 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: GSM Age: 44
Member: 940222 Status: Offline Thanks Meter: 439 | Quote:
01-22-2021, 18:59 | #6 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: ALGERIA
Member: 334901 Status: Offline Thanks Meter: 28 | WHAT IS THE PROBLEM, any solution pls Quote:
