05-10-2018, 08:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | Model XT1723 1+16GB problems on CM2 and AST info from recovery: motorola/panell_23_dl/panell_dl7.0/NRD90M.07.012/012. Information from AST is empty as seen below and i cannot enable factory to complete FRP reset. With CM2 i've found a custom da.bim that can boot the phone, but again, it's not possible to do FRP reset. Logs below. Maybe someone can help with usefull information. Moto Tab: Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ Model Info ============ SW Info ============ HW Info ============ Lock Info ============ Done! Elapsed: 00:00:09 ADB TAB: Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : max-download-size: 0x8000000 INFO : partition-size:flashinfo: 1000000 INFO : partition-type:flashinfo: raw data INFO : partition-sizetp: 2b00000 INFO : partition-typetp: raw data INFO : partition-size:userdata: 32000000 INFO : partition-type:userdata: ext4 INFO : partition-size:cache: 19000000 INFO : partition-type:cache: ext4 INFO : partition-size:system: a9000000 INFO : partition-type:system: ext4 INFO : partition-size:metadata: 2500000 INFO : partition-type:metadata: raw data INFO : partition-size:nvdata: 2000000 INFO : partition-type:nvdata: ext4 INFO : partition-size:frp: 100000 INFO : partition-type:frp: raw data INFO : partition-size:tee2: 500000 INFO : partition-type:tee2: raw data INFO : partition-size:tee1: 500000 INFO : partition-type:tee1: raw data INFO : partition-size:keystore: 800000 INFO : partition-type:keystore: raw data INFO : partition-size:secro: 600000 INFO : partition-type:secro: raw data INFO : partition-sizeemkeystore: 200000 INFO : partition-typeemkeystore: raw data INFO : partition-size:seccfg: 80000 INFO : partition-type:seccfg: raw data INFO : partition-size:expdb: a00000 INFO : partition-type:expdb: raw data INFO : partition-size:logo: 800000 INFO : partition-type:logo: raw data INFO : partition-size:recovery: 1000000 INFO : partition-type:recovery: raw data INFO : partition-size:boot: 1000000 INFO : partition-type:boot: raw data INFO : partition-sizeara: 80000 INFO : partition-typeara: raw data INFO : partition-size:lk: 80000 INFO : partition-type:lk: raw data INFO : partition-sizerotect2: a00000 INFO : partition-typerotect2: ext4 INFO : partition-sizerotect1: a00000 INFO : partition-typerotect1: ext4 INFO : partition-size:nvram: 500000 INFO : partition-type:nvram: raw data INFO : partition-sizeroinfo: 300000 INFO : partition-typeroinfo: raw data INFO : partition-sizereloader: 40000 INFO : partition-typereloader: raw data INFO : off-mode-charge: 1 INFO : warranty: yes INFO : unlocked: no INFO : secure: yes INFO : kernel: lk INFO : product: A158_SEC INFO : version-preloader: 0.1.00 INFO : version: 0.5 INFO : efuse: yes INFO : ro.emmc_size: 16GB SAMSUNG INFO : ro.ram_size: 1GB INFO : SKU: XT1723 INFO : hwrev: WKHMA1B2-2 INFO : imei1: 355645087718139 INFO : imei2: 355645087718147 INFO : ro.build.version.full[0]: Blur_Version.25.071.012.panell_ INFO : ro.build.version.full[1]: 23_dl.retail.en.US INFO : ro.build.fingerprint[0]: motorola/panell_23_dl/panell_dl INFO : ro.build.fingerprint[1]: :7.0/NRD90M.07.012/012:user/rel INFO : ro.build.fingerprint[2]: ease-keys INFO : kernel.version[0]: Linux version 3.18.35+ (wind-ke INFO : kernel.version[1]: rnel@droid) (gcc version 4.8 (G INFO : kernel.version[2]: CC) ) #1 SMP PREEMPT Wed Jun 21 INFO : kernel.version[3]: 10:29:55 CST 2017 INFO : ro.serilno: ZW2222X49R INFO : ro.carrier: noset INFO : radio: LWG INFO : state: NOT Rooted INFO : Done!! OEM : FAILunknown command Done! Elapsed: 00:00:09 Enable Factory. Phone goes into chineze menu then we have this: Operation : Moto ADB Enable [ v1.03 ] Mode : Enable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Error : Device NOT accept CMD/Data! Remove battery, cable. Check cable and connection. Repeat operation! And on CM2, with the only custom DA.bin I found working we can read info but not reset frp or read flash (bin format or other): Read info: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323145633C0D420BBCF0CE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420D3C63CEF0440B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7D78BC9B11719BCDA8ED99FEF690F46F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : motorola ProdName : panell_23_dl ProdModel : Moto C Plus Device : panell_dl AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_gr6737m.35.le.n_P69 SECURITY : IMEI_OTP [1] : 355645087718139 IMEI_OTP [2] : 355645087718147 Done! Elapsed: 00:00:26 Reconnect Power/Cable! Erase FRP: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323145633C0D420BBCF0CE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420D3C63CEF0440B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7D78BC9B11719BCDA8ED99FEF690F46F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Format/Reset Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Read full flash: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323145633C0D420BBCF0CE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420D3C63CEF0440B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7D78BC9B11719BCDA8ED99FEF690F46F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Read error Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! With SP tool, if i try to write FRP image i get PMT error. |
05-10-2018, 14:29 | #4 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | The problem with this phone is that you cannot select factory mode with volume down combination keys. It boots directly into chinese test mode. |
05-10-2018, 21:41 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Download: Moto_C_Plus_XT1723_FRP_TWRP You have all inside. Use CM2MTKv2_r2, loader+auth file, Flash frp package from archive. (That should pass in normal mode, no need for Volume down + insert usb) b.r Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 05-10-2018 at 21:47. |
The Following 10 Users Say Thank You to Brka For This Useful Post: |
05-11-2018, 07:14 | #6 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | 10x Brka. Solved FRP with SP tool 5.1628, your DA_PL & Scatter & FRP files. |
The Following User Says Thank You to Alinus For This Useful Post: |
