10-20-2007, 08:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Motorola C139 Cingular Unlock Ok With Infinity Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.9.24 HW version: _E88 LP ver: LPN_C139_NA2_00X Flex ver: FFN_C139_4R_10X imei otp: 011198009485946 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_011198009485946_20071020-124744.31E.bin imei eeprom: 011198009485946 Check Flash-2 Done Write... Write Done Finished, time used: 41 sec Remove/Install battery now ! READ EPROM COM6 [VCP0] selected Action: read eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.9.24 HW version: _E88 LP ver: LPN_C139_NA2_00X Flex ver: FFN_C139_4R_10X imei otp: 011198009485946 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_011198009485946_20071020-124624.31E.bin reading ... file saved: backup_eeprom_ffs_011198009485946_20071020-124630.31E.bin reading ... file saved: backup_eeprom_system_log_011198009485946_20071020-124631.31E.bin Finished, time used: 18 sec Remove/Install battery now ! |
10-31-2007, 06:20 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Chittagong, Bangladesh.
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | Bad luck! I cannot unlock for c139 (cinguler) after cut truck. Phone not booting for any operation. here is some info cpu: D751749ZHH 75AYD6W D Flasher: MemoCom KI03204BT-Gb1 0723-KS ECB6Y7804 |
10-31-2007, 14:40 | #10 (permalink) |
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | yes on. and when connect cable then display gone. remove cable then lcd ok. few days ago i have same problem for same model & operator. |
11-01-2007, 12:46 | #11 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 60
Member: 108346 Status: Offline Thanks Meter: 58 | Quote:
11-01-2007, 18:37 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! @tuhingr: If after cutting track phone still can be powered ON- that means this is new PCB where test point is sourced under CPU. to make such phone you must remove CPU, reball it, and solder back without ball on leg N1. @ktbachkhoa: please post a log |
>>> Permanently Blocked Alcatel E227x Unlocked Ok with infinity <<< | zeel_zeel | Infinity-Box | 7 | 09-07-2009 13:39 |
now vodafone228fm by zte with counter blocked unlock ok with infinity | genci titi 2002 | Infinity-Box | 2 | 01-19-2009 13:44 |
alcatel s107 unlock ok with infinity box | kopsa2005 | Alcatel & TCL Old Models | 11 | 07-02-2008 09:32 |
another voda 226 unlocked ok with infinity | keaelite | Infinity-Box | 1 | 06-20-2008 11:14 |
<<<< LG KG225 Unlock ok with Infinity >>>> | dog_baby | Infinity-Box | 1 | 01-19-2008 08:32 |
