08-21-2019, 11:13 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: United Kingdom
Member: 670771 Status: Offline Thanks Meter: 9 | Motorola w337 unlock I’m trying to unlock few old Motorola phone with infinity box But whatever I do can’t connect the phones I use rg45 cable I choose the com port which connected to box But can’t connect the phone Not sure is this something special we have to do or what I tried many Motorola phone old phones Like w377 w375 ete.. Waiting for your advice Thanks |
08-21-2019, 21:21 | #3 (permalink) |
Member: 670771 Status: Offline Thanks Meter: 9 | Hi There is no log It’s simply says connect your phone and press power button I do that but not connecting at all I tried many Motorola phones I be able unlock lg phones or other models Sony Ericsson But for Motorola not comecting Not sure is there something I’m doing wrong |
08-21-2019, 22:02 | #4 (permalink) | |
and you should post full details about model but not "Motorola phone old phones". | |
08-22-2019, 10:01 | #5 (permalink) | |
Member: 670771 Status: Offline Thanks Meter: 9 | Quote:
It’s stated Motorola w377 Or Motorola w375 Also why you need log When you know that it’s very simple When u open the tool what you will see That is No connection between box and phone So I don’t know is that log that important when you stater the tools You know what log you get However this is the log COM55 [VCP1] selected module v1.38 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! Whatever I do is not make connection to the phone I tried 2 set rg45 cable For must Motorola phone I have this problem Can do with other phones lg Sony | |
08-22-2019, 12:25 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | yes you are right, it's very simple ! if you see nothing after "Press Power button now !" it means you have something wrong with cable. you must double check cable and try again. do you have cable picture ? result ? |
08-22-2019, 12:46 | #7 (permalink) | |
Thanks for replay I have 2 set cable for Moto t191 And Panasonic cable x60 Which is use to unlock the w377 Or w375 In meantime it’s always like this for Motorola phone not sure Can do other phones like Sony etc.. | |
08-22-2019, 18:34 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | if you ask about Panasonic cable I think your problem is really woth wrong cable selection. just run Infinity-Box Shell, select your model and you will see pinout for legacy Motorola models. you can try all 3-pin cables like at your photo. in some cases you must cut connector plastic so connector fit well |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
08-22-2019, 22:31 | #9 (permalink) | |
Thanks | |
08-23-2019, 10:01 | #10 (permalink) | |
Just want to let you know even after cutting the bit of cable still not any luck I’m not sure what to do else ! What ever I do change setting com port even using different box com port still not connecting it’s not only one Motorola all Motorola phone So we can say all this phone can’t be faulty There should be something wrong with mu box ! Or something wrong with my hmodule tool | |
08-23-2019, 22:49 | #11 (permalink) | |
f.e. for W375 you must use Moto01 module but not HModule. How about to install Infinity-Box Shell at least now ? | |
08-27-2019, 17:20 | #12 (permalink) | |
Thanks for replay The problem we have is with any Motorola phones I tried you recommendation Still same problem I used other phones Sony Ericsson lg It’s work fine | |
